Author Topic: Okay,so whats the difference?  (Read 716 times)
Offline Bane
  • "I was born a handsome man and now I'm half a goat
« on: December 09, 2013, 10:58:31 pm »
Between FSI,TSI and TFSI?
I'm of the opinion the FSI and TFSI is Fuel Stratified Injection and the T is for Turbo,so whats TSI? :confused:
Offline Chris92
  • -Given: 33
Re: Okay,so whats the difference?
« Reply #1 on: December 09, 2013, 11:36:30 pm »
TSI-turbo stratified injection
As far as I know anyways.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: December 09, 2013, 11:51:07 pm »
http://en.wikipedia.org/wiki/List_of_Volkswagen_Group_petrol_engines
This latest EA888 family of internal combustion engines is anticipated to be an eventual complete replacement of the EA113 range. It was wholly designed and developed by AUDI AG. The only common feature with its predecessors is the sharing of the same 88 millimetres (3.46 in) cylinder spacing - which keeps the engine length relatively short, meaning it can be installed either transversely or longitudinally. Grey cast iron (GJL 250) remains the choice material for the cylinder block and crankcase, due to its inherent good acoustic dampening properties. This all-new EA888 range is notable for utilising simplex roller chains to drive the two overhead camshafts, instead of the former engines' toothed-rubber timing belt. Like the final developments of the former EA113 engine generation, all EA888s only use the Audi-created Fuel Stratified Injection (FSI) direct injection. Furthermore, EA888 engines are also able utilise the Audi-developed 'valvelift' technology, which complements the existing variable valve timing. This new family of engines is scheduled to be universally available for all markets on five continents, within all marques of the Volkswagen Group. The former EA113 range still remains in production.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #3 on: December 10, 2013, 12:34:23 am »
This latest EA888 family of internal combustion engines is anticipated to be an eventual complete replacement of the EA113 range. It was wholly designed and developed by AUDI AG. The only common feature with its predecessors is the sharing of the same 88 millimetres (3.46 in) cylinder spacing - which keeps the engine length relatively short, meaning it can be installed either transversely or longitudinally. Grey cast iron (GJL 250) remains the choice material for the cylinder block and crankcase, due to its inherent good acoustic dampening properties. This all-new EA888 range is notable for utilising simplex roller chains to drive the two overhead camshafts and for having a poorly designed tensioner which causes the engine to eat itself from within, instead of the former engines' toothed-rubber timing belt. Like the final developments of the former EA113 engine generation, all EA888s only use the Audi-created Fuel Stratified Injection (FSI) direct injection. Furthermore, EA888 engines are also able utilise the Audi-developed 'valvelift' technology, which complements the existing variable valve timing. This new family of engines is scheduled to be universally available for all markets on five continents, within all marques of the Volkswagen Group. The former EA113 range still remains in production.
'07 Red manual
