Author Topic: Kenwood DnX520bvt poor radio signal was fine with rcd300 what could it be  (Read 1486 times)
Offline gjseb16
As above guys any ideas radio reception is rubbish now fitted new Kenwood any ideas
Offline skard
  • -Receive: 245
Re: Kenwood DnX520bvt poor radio signal was fine with rcd300 what could it be
« Reply #1 on: December 12, 2013, 11:00:18 pm »
You likely need a powered amplifier, they are under a tenner on ebay. Forgot the part number but if you search on ebay you'll see some variants.
Offline f1fan
« Reply #2 on: December 13, 2013, 02:21:19 pm »
You either need
http://www.roadradio.com/wiring-fascia-adaptors/PC5-136/5973/
http://www.roadradio.com/wiring-fascia-adaptors/CT27AA25/5975/
depending on whether your existing aerial connection is a single or twin fakra.  Connect the blue with to a 12v+ power source and the aerial amplifier will have power and you'll get a decent signal.
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
Offline J12spk
  • VW PERVERT
« Reply #3 on: December 13, 2013, 03:39:15 pm »
Keen to know if either of these work?
Das Auto
Offline w33gry
There was two options. A plug on back of stereo has two inputs looks like it didn't match harness but there is one plug from original harness that goes into it so get the reception hope this helps I'll try get a pick of mine
Offline gjseb16
Tried both adaptors above no improvement at all could do with pick mate if you can
