Author Topic: Ive mostly been fitting TPMS today  (Read 14599 times)
Offline mortygttdi
  • -Receive: 146
« on: September 18, 2009, 05:16:28 pm »
Due to having such a low profile tire on my alloys(215/35) I needed abit of protection, so I bought the wiring loom for the tpms from Kufatec and the switch from Vw dealer and fitted yesterday easy enough to do just needed coding which again is easy to do,  Ive not got any pics of the install but i do of the switch and cluster icons.
Darren
Offline cmdrfire
    • Commander Fire - my blog
Re: Ive mostly been fitting TPMS today
« Reply #1 on: September 18, 2009, 05:32:58 pm »
Is this active TPMS or the passive TPMS?
I see from your gauges you don't have a GTI: the RoW-spec GTI comes with the passive TPMS (which isn't nearly as good as the US-spec active TPMS, which both Golfs (Rabbits) and GTIs get in the US).
Offline golfman
  • -Given: 17
« Reply #2 on: September 19, 2009, 01:55:15 pm »
Darren
very  8) darren nice job :happy2:
sent you pm m8!!!
Vag-com Hex+Can in scotland
I Hate Timewasters...
« Reply #3 on: September 19, 2009, 07:08:25 pm »
I bought this in jan and have never fitted it!
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: September 19, 2009, 07:20:06 pm »
Cheers Scott I'll PM you back in a minute mate
Get it on Jay especially with your wheels being has expensive has they are...Jay could you give me a low down on how to do the xenons, Ive got some that I picked up the other day and Im just waiting for the adapters from Kufatec.
Darren
Offline Norbreck21a
« Reply #5 on: January 30, 2010, 10:35:58 pm »
Darren,
sorry to dig up and old thread, but any chance you could elaborate a little more on what's involved in retro fitting TPMS (parts, approx cost, how to etc.)
This is the next mod on the list.
« Reply #6 on: January 30, 2010, 11:26:05 pm »
You'd be better off fitting one of these...
It gives individual pressure and temperature readings of tyres and you can set upper and lower limit warnings for both.
More info here.....
http://www.mk5golfgti.co.uk/forum/index.php?topic=8314.0
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: January 31, 2010, 09:06:53 am »
This is the guide off World Impex although I got the harness from Kufatec
http://www.worldimpex.com/assets/partdocuments/TPMS1.pdf
Any probs you know where I am
Darren
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #8 on: January 31, 2010, 10:25:49 am »
What's the difference between the active and passive variants?
Offline Bogwoppit
« Reply #9 on: January 31, 2010, 02:31:26 pm »
I'm guessing that the passive system uses the cars ABS/ESP system to tell if a tyre is going flat.
As the tyre has less air in it, its circumference decreases so the ABS/ESP system will notice that the tyre is spinning quicker than the others .
An active system relies on individual pressure monitors being fitted to each wheel/tyre. The active systems will be a lot more accurate than the passive. The passive system will only notice a large drop in PSI not a small one.
« Last Edit: January 31, 2010, 02:34:50 pm by Bogwoppit »
  • MUBster DUBster
« Reply #10 on: January 31, 2010, 03:57:19 pm »
So, presumably the tyre pressure control I have on my car is a passive one?
Had my tyres changed a month or so ago.  Didn't notice any special sensors behind the valves on the rims - similar to the ones on my previous car.
Someone on this forum suggested the tyre pressure control worked using a ride height sensor...so I guess that was a bit of "bum fluff" - put politely!
« Reply #11 on: January 31, 2010, 04:14:17 pm »
Had my tyres changed a month or so ago.  Didn't notice any special sensors behind the valves on the rims.
Unless you purchase an aftermarket setup, the stock golfgti has the passive system. I had a drop of 10psi before the warning came on.
Offline deccae
« Reply #12 on: February 03, 2010, 01:00:41 am »
I have the aftermarket TPMS and its great.
I've hardwired it into my car as i was going to leave it permanently connected.
However it does emit an annoying loud beep when you start the ignition
so i plug it in only when i want to check the tyre pressures.
Offline rjwojcik
« Reply #13 on: February 03, 2010, 01:11:06 pm »
Is it this?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170360547571&ssPageName=STRK:MEWAX:IT
Sounds like a good investment, can you get additional sensors for a spare set of wheels?
Offline gttdigoof
    • bf1systems
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,104209.0.html
« Reply #14 on: April 30, 2011, 09:53:27 pm »
I run this in my car
http://www.bf1systems.com/products/tpms/TPMSInfraRED.html
As used by several F1 teams :wink:
 Mk6 R :)
