Author Topic: Advice with noise... Help :S  (Read 680 times)
Offline Covgttdi
« on: December 16, 2013, 06:31:02 am »
Hi all this morning left for work and noticed a slight screeching/rubbing/grinding noise cumming from the front passengers wheel, i cant see anyfink touching or loose. The car not long had new break bads and disc last month when i brought it, anybody have any ideas can only realy hear it when im going around 10-20 mph. Thanks
Offline doylebros
Re: Advice with noise... Help :S
« Reply #1 on: December 16, 2013, 07:10:43 am »
Stone between disc and back plate is very common for that type of fault.
Quite often it drops out before you get a chance to remove it
Offline Covgttdi
« Reply #2 on: December 16, 2013, 07:37:29 am »
I will have to take wheel off after work just thought wouldnt be that as the noise isnt constant?
Offline Llew
  • -Given: 45
« Reply #3 on: December 16, 2013, 07:48:34 pm »
Worn brakes,loose nuts, or wheel bearing would be my first port of call - if that helps
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
