Author Topic: Mk5 ABS loom repair  (Read 6756 times)
Offline shultsy12
Mk5 ABS loom repair
« on: December 16, 2013, 11:28:25 am »
Basically, ive ended up breaking the wiring loom for my ABS, i repaired the loom with connectors to stop high resistance and over 100mph all the lights come on my dash ABS, TPMS, and traction control, i then tried soldering it same issue has occured has anyone successfully repaired an ABS loom if so what did you use, im trying to get a price for a new loom from vw but their just a pain in the ass! also does anyone know where the connector fro that loom is its the passenger side
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Mk5 ABS loom repair
« Reply #1 on: December 16, 2013, 12:01:52 pm »
Are you refering to the loom for the ABS sensors or the Loom that is for the Pump?
also are you sure the sensors are ok
Cluster and Key coding
Location Great Yarmouth
Offline shultsy12
« Reply #2 on: December 16, 2013, 02:15:00 pm »
refering to the loom that goes from the module to the sensor, yes they are all good working order
Offline doylebros
« Reply #3 on: December 16, 2013, 05:07:37 pm »
Does this help you identify what your after?
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1731&ein=2008&f=625&hauptgr=1234567890&hg=9&grf=092701409&bf=92701&hgug=927&ug=27&parent_id=2869252
Offline shultsy12
« Reply #4 on: December 30, 2013, 06:33:58 pm »
Right got a new loom from vw and fitted it today, chased the wiring through the wheel arch into a massive loom, removed tape from the loom to expose the wires, cut the correct wires and soldered the new ones into the loom, road tested still have the same issue now I'm puzzled!! Has anyone repaired abs looms before?
Offline doylebros
« Reply #5 on: January 01, 2014, 01:36:01 pm »
Sure this isn't an issue with the sensor information?
Could be the wheel bearing ring or the Abs sensor it's self, if you've made a good repair to the harness!
Why did the harness get damaged originally, were you looking for the same fault and damaged the harness doing so?
Bower had an issue not too dissimilar read his posts and see if that helps with warning light issues.
http://www.mk5golfgti.co.uk/forum/index.php/topic,73909.0.html
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: January 01, 2014, 09:09:00 pm »
Front or rear sensor wiring?
Follow AKS tuning on Facebook
