Author Topic: Drivers door loom - part number  (Read 2223 times)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« on: December 16, 2013, 11:28:18 pm »
Drivers door lock has stopped unlocking by the key fob, VCDS brought up 00470 - Combination comfort Databus in Single Wire. Checked the loom at the plug end as it plugs into the body and the orange Canbus wire has snapped off at the connector  :fighting:
Incase i can't fix it, does anyone have a part number for a drivers side door loom for a 2007 Golf, 5 door with electric folding, heated (not auto dimming) mirrors.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Drivers door loom - part number
« Reply #1 on: December 16, 2013, 11:36:19 pm »
yo will have to buy some repair wires
Cluster and Key coding
Location Great Yarmouth
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #2 on: December 16, 2013, 11:37:39 pm »
Looks like i'll need to replace both Canbus wires, will they both need to be the same length?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: December 22, 2013, 09:12:48 pm »
Partially stripped the door down today, fixed the broken wire, visually inspected the loom but couldn't see a massive amount as i hadn't removed the door skin. Cleared the fault code, took the car for a drive and rescanned BUT i'm still getting the same fault so there must be a broken wire elsewhere. If i'm going to remove the door skin i might as well replace the loom, with that said i am completely confused as to which loom i need.
Looking at Partsonline i'm not sure which one i need.
The Golf is a 2007 (Made June 2007) 5 door with out sound pack but i am completely confused as to which one i need.
Offline doylebros
« Reply #4 on: December 23, 2013, 04:39:38 pm »
Yes, tricky!
Need the chassis number to be 100%  :happy2:
1k0 971 120 CH - £89.50 full retail inc vat
