Author Topic: Coolant Temp  (Read 5156 times)
Offline Itguy
Re: Coolant Temp
« Reply #15 on: December 27, 2013, 07:35:58 pm »
On an early gti. 2005 model. Do I have to drain the coolant in order to change the main thermostat. I know I do for the smaller ones. Just wanted to confirm for the main
Yes you do
Offline Human Joist
Re: Coolant Temp
« Reply #16 on: December 27, 2013, 08:19:56 pm »
Cheers bud
Offline Itguy
Re: Coolant Temp
« Reply #17 on: December 27, 2013, 08:37:45 pm »
It's obvious when you get in there but the thermostat is on the side of the engine block about half way down, probably in the worst position possible for DIY!
Offline Human Joist
Re: Coolant Temp
« Reply #18 on: December 27, 2013, 09:16:41 pm »
Am hoping I don't need to change that one. My car holds 90 when it gets there but it takes nearly 10 miles to do so. I was thinking it's the two smaller thermostats that have failed.
Offline jamma
Re: Coolant Temp
« Reply #19 on: January 07, 2014, 01:12:00 pm »
Part is about £35 (if it is actually the main thermostat housing you need, rather than any of the other thermostats your car may have).
Changing main thermostat is about a 3-4hr job DIY depending on how good you are with the spanners and if you have all the right kit.
Cheers , I need the cambelt done too,  so cambelt, water pump and thermostat is 480 quid so will get it all done at once.
Offline Ranbeer Singh
Re: Coolant Temp
« Reply #20 on: January 09, 2014, 08:05:26 pm »
Update.
Changed the main thermostat and car is back to normal  :driver:
Thanks chaps
Offline Wolf Burger
Re: Coolant Temp
« Reply #21 on: January 09, 2014, 08:08:01 pm »
Update.
Thanks chaps
Mine being done in the next couple of weeks.
How long and how much mate?
Golf Mk6R 2011- Rising Blue- Manual-
Modifications-
E-Tuners 361 BHP - 350lbs
Revo Intake
Bilstein B16 & H&R ARB's
Team Dynamics 1.3
18Z Porsche BBK
RNS510 with Focal Speaker upgrade
MK6 Recaro Heated Buckets
Cruise Control
Highline Reverse Camera
Offline OSB
  • -Given: 32
Re: Coolant Temp
« Reply #22 on: January 10, 2014, 07:59:07 am »
VW Book Time is 3hrs.
DIY time seems to be 3-4hrs depending on skill, access etc - there is probably someone out there who has done it quicker though!
Re: Coolant Temp
« Reply #23 on: January 10, 2014, 12:26:18 pm »
Quote
HI Mate,
Got my mechanic to do it.
3hrs work
£80.00 labour
£30.00 thermostat
£5.00 coolant
£115.00 all in
cheers
Offline Human Joist
Re: Coolant Temp
« Reply #24 on: January 12, 2014, 08:42:22 pm »
Right update. Drained the coolant and found a good place to do so of a link On here by removing a pipe on a low point and letting it all come out neatly. Did not bother with any proper drainage points. Then replaced both smaller thermostats. Both were completely knackered and I could not even move them with pliars. The only trouble I had was the clips were the wrong way round so could not get straight on to the spring part. Sorted filled back up and back on the road. Just want a cold star to check it's sorted.
