Author Topic: Help fitting Cruise - Slough area  (Read 1899 times)
Offline Gti Jal
« on: September 20, 2009, 05:13:29 pm »
Hi Fella's,
Can anyone with VAG COM help me with fitting cruise around slough?
Thanks,
Rik.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Help fitting Cruise - Slough area
« Reply #1 on: September 20, 2009, 06:38:44 pm »
Not perfectly local but Hedge has VCDS if you're willing to travel.
Failing that look at the list of owners in the VCDS forum.
« Last Edit: September 20, 2009, 06:40:36 pm by vRStu »
Stu...
Offline Gti Jal
« Reply #2 on: September 20, 2009, 10:10:33 pm »
Thanks - I'm going to put it in and then see if I can get some help with VAG COM.
Offline Poppa Dom
« Reply #3 on: September 20, 2009, 10:35:33 pm »
I'm close to M4 J11.
Offline Gti Jal
« Reply #4 on: September 20, 2009, 10:53:07 pm »
Hi Dom,
I'll get it installed and if ok with you give you a shout via PM
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: September 21, 2009, 03:47:06 am »
Be careful with the steering controller when you remove it.  You'll likely get a steering wheel warning on the dash when you put it back together, just drive a few yards in a straight line and it will clear.
Stu...
Offline Poppa Dom
« Reply #6 on: September 21, 2009, 08:13:17 am »
That's fine -just give us a PM as and when. Stu - got any coding guidance?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: September 21, 2009, 12:43:55 pm »
Assuming it's a GTi then it's ECU Long Coding and Steering Controller if it's a TDi then it's ECU login (11463) and Steering Controller.
Stu...
