Author Topic: Fitting a LSD - few questions  (Read 3719 times)
Offline Syrag64
« on: December 20, 2013, 09:22:17 pm »
I have the LSD, complete new clutch and have just ordered the 2 diff bearings & shims, I also need some sealant, VW quoted £60 for this, can I use an alternative thats cheaper?
Also on my car at the moment sometimes the clutch pedal stays down and I have to lift it with my toe, do I need a new master or slave cylinder?
Also I am going to fit new engine mounts, is there anything else I should do whilst I'm doing all this?
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Matto
  • -Receive: 116
Re: Fitting a LSD - few questions
« Reply #1 on: December 20, 2013, 10:20:11 pm »
Factor in a wheel alignment also as I believe the subframe has to be removed  :happy2:
Offline xjay1337
  • -Receive: 377
« Reply #2 on: December 20, 2013, 10:30:10 pm »
Your driveshaft would need to come out, subframe stays in place. I've done my gearbox (on my TDI same method exactly) 5 times. Never needed an alignment afterwards.
The issue you mention regarding the pedal is indicative of a slave cylinder failure.
Offline Syrag64
« Reply #3 on: December 20, 2013, 10:48:19 pm »
I shall get a new one ordered then cheers  :happy2:
  • -Receive: 427
« Reply #4 on: December 20, 2013, 11:06:58 pm »
As your Subframe is off for the clutch bits why not fit a new uprated front anti roll bar too, perfect time!  :wink:
Offline Syrag64
« Reply #5 on: December 20, 2013, 11:09:40 pm »
Already done  :happy2:
Offline xjay1337
  • -Receive: 377
« Reply #6 on: December 20, 2013, 11:45:50 pm »
Would be a good time to do it but you don't NEED to drop the subframe it gives very little extra space to be honest.. !! A waste of time IMO.
You don't need to take the subframe off to do the roll bar either, undo the bolts a bit and it'll drop down enough to get the bar out.  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: December 21, 2013, 07:58:02 pm »
Your TDi was 5 speed though?
Follow AKS tuning on Facebook
Offline xjay1337
  • -Receive: 377
« Reply #8 on: December 22, 2013, 10:22:31 pm »
Yeah it was.
6 speed Mk4 is a bit more tricky.  From the DIYs ive read of a MK5 GTI (having done my TDI one countless times, got bored of it in the end  :signLOL: :signLOL: ) you dont need to remove subframe on these either.
Happy to be corrected if tjatthat's the case :)
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: December 23, 2013, 02:21:14 pm »
Yeah it was.
5 speed falls out.  6 speed removal and fitting is far faster with the subframe removed.  I mark the subframe positions so it 99% back in the correct place.  It can be done with the frame still on, but its an arse.
Offline xjay1337
  • -Receive: 377
« Reply #10 on: December 23, 2013, 02:42:08 pm »
I see, good to know. Cheers Alex  :happy2:
Offline Chrismeardon
« Reply #11 on: December 25, 2013, 08:09:06 pm »
Any differences in effort between fitting on a manual vs DSG?
« Reply #12 on: December 25, 2013, 08:47:54 pm »
You have to be very careful when cracking open the DSG box as it needs to be separated from the mechatronics unit when getting at the diff. Oil refill needs a tool to do too.
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: December 26, 2013, 09:12:59 am »
Loads more effort. A lot more to mess up too. I've done enough of them now to have a good routine to get them right.
