Author Topic: Boost Pressure Control Valve (N249)  (Read 17567 times)
Offline Scuba
« on: December 21, 2013, 07:57:03 pm »
Hello everybody the below error showing on my GTI 2007 .as i can see that most of the people having this issue is related to DV .i have already replaced the PCV 4 months ago and today i have removed the DV which is in good shape but revision c . any idea what should be the next part to check
2 Faults Found:
008801 - Boost Pressure Control Valve (N249)
               P2261 - 008 - Mechanical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:52:35
             Freeze Frame:
                    RPM: 2244 /min
                    Load: 11.0 %
                    Speed: 45.0 km/h
                    Temperature: 85.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.589 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:58:05
             Freeze Frame:
                    RPM: 762 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 88.0°C
                    Temperature: 33.0°C
                    Voltage: 13.462 V
thanks
Offline GLIDN
Re: Boost Pressure Control Valve (N249)
« Reply #1 on: December 21, 2013, 08:36:27 pm »
First error message will be your DV replace that.
I you also get a incorrect pressure or exceeded pressure.
Your N75 has failed.
For your P0441 error, replace the N80 valve with new revised hose from N80 to line that's goes to the charcoal canister.
Offline martin@gti.co.uk
« Reply #2 on: December 21, 2013, 10:20:33 pm »
As described DV fault. Underboosting. Get new DV and your sorted. I use k04 rev.g DV. Not sure if C is the one wit rubber diaphrame..prone to fall apart. Located on your turbocharger.
Offline Scuba
« Reply #3 on: December 22, 2013, 06:57:17 am »
i took pictures for the DV when i remove it ,i took it out and checked the diaphragm and the rubbers look fine no scratch or crack it is opening and closing properly as well.
is it possible that the DV gives such error even if the diaphragm look good? here attached the pictures[/img][/img]
« Last Edit: December 22, 2013, 06:59:53 am by Scuba »
Offline Scuba
« Reply #4 on: December 22, 2013, 07:04:26 am »
i am not able to attach the pictures any idea how
Offline edd666999
  • -Receive: 89
« Reply #6 on: December 22, 2013, 12:54:53 pm »
Try to remove it and do your output test on that solenoid valve. To see if it closes when energized. Might strugle to close. But I would put my money on it, that if you fitt a newer rev. It will get your boost issue cured.
Offline Scuba
« Reply #7 on: December 22, 2013, 03:41:38 pm »
here we go attached the pictures
Offline edd666999
  • -Receive: 89
« Reply #8 on: December 22, 2013, 08:08:07 pm »
It's not that we don't believe you when you say it's ripped. It's that rev c is quite old and should be replaced anyway  :happy2:
Those pictures show nothing of interest.
Offline Scuba
« Reply #9 on: January 30, 2014, 06:45:33 pm »
well i bought the new DV revision G which is the new one i have replaced ,cleared the error code and did a small ride its true that i  can feel power boost but whe i came back home i connect the VCD and found 1 new error as below .
is it related to the new DV i have replaced or it was supposed to be ?
i have already replaced the PCV with the new revision as well couple of months before so it should not be related to pcv
any suggestion ?
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 156932 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:56:19
             Freeze Frame:
                    RPM: 748 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.462 V
Readiness: 0010 0101
« Reply #10 on: January 30, 2014, 07:21:56 pm »
any suggestion ?
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 156932 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:56:19
             Freeze Frame:
                    RPM: 748 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 42.0°C
                    Voltage: 13.462 V
http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089
