Author Topic: Harz's GTI R-Tech stage 2, Recaros and Audi FB steering wheel.  (Read 56903 times)
Offline Harz
Re: Harz's GTI getting carried away inc S3 brakes, Hella projectors, valeo rears
« Reply #135 on: September 14, 2014, 09:25:31 am »
Painted bits make the car so much better! and the rear lights!! Love ll the other mods too like dead pedal!
Cheers  :happy2:
Instagram @_harz
Offline Broomy
  • -Given: 18
« Reply #136 on: September 17, 2014, 09:19:00 pm »
Looks well mate, what was done to your skirts, rear valance etc to prep them for painting? Did they have to smooth them?
Offline LeightonJ
« Reply #137 on: September 19, 2014, 07:27:29 am »
Just read through this whole thread... Very nice job  :happy2:
I'm loving those Porsche reps
Offline Harz
Sorry for late reply. Yeah they had to be smoothed/prepped before they were painted.
Instagram @_harz
Offline Harz
Cheers. Still got the LM Reps on it at the mo. There's about 6 sets of wheels I'm trying to decide on... Will hopefully come to a decision and make the change after Xmas.
Instagram @_harz
Offline Harz
Time for a bit of an update.
Fitted the Milltek down pipe and Sports cat.  :smiley:
Comparison of stock and Milltek.
Fitted the THS Intercooler  :smiley:
Removing stock Intercooler
Comparison of THS and stock Intercooler  :smiley:
THS Intercooler in place  :happy2:
My brother was doing his down pipe
Not a mod, but I like it. Picked this up at Players Show 2014  :smiley:
Instagram @_harz
Offline Harz
As the weather is starting to turn worse I thought I'd give the car a bit of a clean and a coat of wax.
Snow foamed with Auto Rae-chem Cherry snow foam
Washed with two bucket method and Britemax Cleanmax shampoo
Then gave a coat of Collinite 845
The finished result
And then 10 minutes after waxing the car it decided to chuck it down with rain
Instagram @_harz
Offline Harz
Re: Harz's GTI R-Tech Stage 2.
« Reply #142 on: October 09, 2014, 10:40:35 pm »
Took the car up to R-Tech
Unfortunately on the drive up to R-Tech my radiator somehow worked loose and the back of the fan rubbed on a coolant pipe and wore a hole in it causing a leak.
The guys at R-Tech managed to wedge a bit of wood to hold the rad in place and despite the coolant leak they were able to do the remap
Had a Stage 2 remap and achieved 270HP and 355ftlbs of torque
"Before" dyno run.
"After" dyno run.
"Comparison" dyno
Peak results
It was then on to the test drive and man did I have an ear to ear grin on my face.
Unfortunately the coolant was leaking pretty bad. It was looking like I wasn't going to be able to make the drive back to London. The lads at R-Tech tried their best to get me the parts and would've done the repair to get me home, but were unable to get the parts.
Luckily the RAC mechanic was able to fix the coolant pipe.
The drive home was amazing :D
Just waiting for parts on order from VW now to sort out rad/coolant pipe.
Instagram @_harz
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Harz's GTI R-Tech stage 2
« Reply #143 on: October 10, 2014, 08:49:55 am »
Saw this on Niki's FB yesterday - great result
How did the rad get loose? Did you use new/correct thread bolts to hold it to the intercooler? There's not a lot of clearance from the fans once you have the new intercooler in place.
Offline Harz
« Reply #144 on: October 10, 2014, 01:20:15 pm »
Cheers the whole rad/intercooler/aircon assembly has come loose. I'm not sure why. Changed the intercooler about 6 weeks ago and I've not had any problems with it, but it somehow worked loose on the drive up to R-Tech. I've not had chance to take the front end off yet to check. I've ordered new rad mountings and screws from VW in case they're damaged. Just waiting for the parts to come and I'll check it out. Got a bit of wood holding it in place at the mo. Not ideal, but at least the car is drivable.
Instagram @_harz
Offline Harz
« Reply #145 on: December 11, 2014, 12:31:33 pm »
Just a small update... Been a quiet couple months. Ordered New mounts/screws from vw for my rad assembly, but haven't had time to take the front end off. Hoping to have it done before Xmas.
Car is also booked in at AKS tuning for end of January for Helix clutch kit and a LSD  :happy2:
Instagram @_harz
Offline Harz
« Reply #146 on: January 05, 2015, 05:03:33 pm »
A couple weeks back I finally got around to taking the front end off to find out why my rad/Intercooler assembly had come loose. The screws had completely come loose and were gone. Checking the new mounts the holes aren't prethreaded, so the first time you put the screws in they create the thread, the only thing I can think of that happened is when I put the screws back into the old mounts I must have messed the thread up somehow and the screws worked loose. Anyway the new mounts are in, the rad/Intercooler assembly is solid and there is adequate clearance between the rad fan and coolant pipes. Glad it's sorted and no longer have a block of wood holding my rad in place :grin:
Instagram @_harz
Offline cupra.al
« Reply #147 on: January 05, 2015, 05:15:14 pm »
where did you get the Collinite 845 applicator or does 845 come like that as ive used 476s in the past and it doesnt come in a liquid form and is a nightmare to use.
Offline Harz
« Reply #148 on: January 05, 2015, 05:18:06 pm »
845 is liquid. And I just used generic applicator sponge.
Instagram @_harz
Offline cupra.al
« Reply #149 on: January 05, 2015, 05:23:56 pm »
oh i was thinking the applicator was attached to the bottle  :signLOL:
