Author Topic: th3_f15t '07 GTI  (Read 70016 times)
Offline th3_f15t
  • -Receive: 183
Re: th3_f15t '07 GTI (New Poll, Page 9)
« Reply #150 on: November 30, 2014, 03:02:44 pm »
any links or help on doing this mate i have mine on and wouldnt mind turning it off
I'll dig out the eBay item you'll need, its just plug it into the wiring clip and clear fault codes.
I'm from torquay a little trip from Dartmoor! Sadly spend all my time at my barracks in Essex lol.. Good bold just read through it all! Thinking bout r32 rear here too! You thought bout colour coding your side skirts?
I have thought about it, but myself and others think the black works well so waiting to see how it looks after I fit my ED30 splitter.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #151 on: November 30, 2014, 07:27:35 pm »
Grabbed myself a set of LED sidelights, seeing as they're all the rage right now.
Before:
After:
Need to get some whiter dipped and full beam bulbs now to finsih the look off. Also going to fit a set of LED interior and number plate nights.
they look spot on, glad yoour happy with them. let me know when you need more
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline th3_f15t
  • -Receive: 183
« Reply #152 on: December 01, 2014, 12:15:13 pm »
Very happy, thanks! Just need to bu some matching white light bulbs and I'm there. Won't bother with xenon lights, too much messing about and cost a bomb!
Offline th3_f15t
  • -Receive: 183
« Reply #153 on: December 06, 2014, 04:24:22 pm »
Fitted my leather door cards, no pictures as they're not complete. Got chromed switches and the metal trims to fit first. Will do that in the new year when its not freezing outside.
Offline th3_f15t
  • -Receive: 183
« Reply #154 on: December 08, 2014, 08:46:56 pm »
This was my car an hour before fitting door cards;
Offline xjay1337
  • -Receive: 377
« Reply #155 on: December 09, 2014, 01:12:42 pm »
Just a bit chilly then!!!
Offline th3_f15t
  • -Receive: 183
« Reply #156 on: December 10, 2014, 04:51:05 pm »
You know what, it was actually really pleasant working in the sun shine, ended up in jeans and a t-shirt, despite the dash saying it was 2 degrees outside. I've become some what efficient at removing and refitting door cards, I can do it without breaking the cheap, black plastic things VW insist on using. 2 door cards completely swapped in under 2 hours.
Offline th3_f15t
  • -Receive: 183
« Reply #157 on: December 15, 2014, 07:19:10 pm »
So I'm happy with my stage 1+ and was focused on not doing any more to the engine until I had chassis, brakes and interior mods all sorted. Then this came up for a silly cheap price;
I now have an S3 intercooler, which I plan to fit along with a Neuspeed hi-flow intercooler pipe (sourced) and K03 hi-flow turbo discharge kit (pending). I'm not bothering with an induction kit as from research the K03 is fine with the stock intake and a panel filter but may invest in a HPFP internals upgrade or APR/Loba pump (should one appear cheap enough).
Oh, and a full BCS system with R32 rear of course... Stage 2 by 2016 looks likely at the rate I'm going. Getting the current list of parts fitted before 2016 however, doesn't!
Offline th3_f15t
  • -Receive: 183
« Reply #158 on: December 28, 2014, 04:54:16 pm »
Got round to fitting my Forge CC pipes today;
Nice bit of engine bling. Needs a good clean up, some red coil packs and wiring harness, plus a few bits of paint here and there to tidy it right up. Mostly it's all hidden under the engine cover but in case a cheap induction kit pops up for sale, despite the last post saying I won't bother with one. Revo or VW Racing intakes are the only ones I'd opt for and they'd have to be at just the right price to temp me.
Offline th3_f15t
  • -Receive: 183
« Reply #159 on: January 02, 2015, 02:36:39 pm »
When I replaced my CC pipe work, I completely forgot to replace the MAF sensor and air feed! My engine wasn't running right at all and it took a fault scan for me to realise I'd missed replacing the air feed and MAF sensor after 2 days. Really shouldn't be near cars with tools, but there you go, lesson learned...
Also begun the task of replacing my centre console and arm rest for a leather one today. Took several hours yesterday to dismantle things and get the old items out the car;
I've had to remove the driver's seat to get it removed, will have to remove the passenger seat as well. It does make life a lot easier though, and my efforts were rewarded;
Then today I began fitted the new alcantara trimmed centre console;
Now fitting the arm rest and trying to figure out how to fit the air vent in the arm rest, it's not easy at all... Stay tuned for finished pictures soon, hopefully with a better quality camera than my phone.
Offline th3_f15t
  • -Receive: 183
« Reply #160 on: January 08, 2015, 09:04:31 pm »
So I also have smoked indicator repeaters, may get some new mirror caps and spray them gloss black to go along with them. Also, in a week's time I shall be taking my car to AKS tuning for a full front and rear SuperPro bushes kit plus H&R anti roll bars. Will probably lower my car by 5mm as well while it's in, possible 10mm but need to check out the speed humps around my area first for clearance! Made no progress with the arm rest yet, but I plan to over the next few weeks.
Offline th3_f15t
  • -Receive: 183
« Reply #161 on: January 16, 2015, 09:57:26 pm »
Looking back through this whole project log and it’s clear that the first half has been a performance focused project but then it became all cosmetic. July was the last performance modification that was done to the car in the form of Bilstien B14 coilovers from AMD Tuning. Since then it was all interior focused really, as I wanted to make the driving experience inside as good as it was underneath. I don’t regret such a change in priorities but lately I’ve lost a lot of motivation for cosmetic modifications as they are a lot of work (sourcing, planning and in some cases, fitting) and although pretty, do very little to change the feel of the car when driving.
That all changed today…
My day started well, woke up on time, got ready and left for the drive from London to AKS Tuning in Bedford with a pit stop for fuel at Tesco. £1.10 a litre for premium and less than £50 to fill up from just below a quarter. Then onto the M1 which was clear enough that I could cruise at 70 the whole way there, also didn’t get lost. Booked it to start at 9am and I arrived exactly on time. A good omen, or too much luck used up too early? Well…
A good omen. Had a quick chat with Alex (who is as nice as people say) and he laid out everything for me to look at and take pictures for this log;
So if you don’t know already, I put my name down for the SuperPro group buy to take advantage of a good discount on the full front and rear upgrade kit for my Golf. Also asked to have H&R anti-roll bars fitted as it seemed sensible while the whole suspension system was pulled apart. Plus the quoted price was the same price AMD Tuning where asking for just the SuperPro kit on its own! How can I refuse that kind of bargain?
Watching Alex work is hypnotic, found myself just staring and watching in wonder, but pulled myself together long enough to get some “in progress” shots for you all to enjoy.
Anti-lift kit;
Anti-roll bar;
Torque mount insert;
The rear assembly taken apart;
The ball joints put up a protest and several of the bolts sheared off which was expected but strangely, I didn’t think of asking to have the SuperPro versions added to my shopping list so some stock ones are on for now but may upgrade on my next visit to AKS. At 6:45pm (just shy of 10 hours later) I paid up and got the keys back.
I’m not going to talk about the kit just now (bizarrely) as I was really tired and hungry after spending most of the afternoon playing GT5 while waiting plus it was the end of rush hour so going to get a few hundred miles on the various bits before forming an opinion on the upgrades. Annoyingly, I asked if I could drop my suspension down another 10mm ahead of my first track day in March but when we had a look at the Bilstiens it was quickly apparent they are already wound down fully (their max of 50mm) so there’s no more left in them in terms of drop. I’m happy with the way the car sits but wanted that little bit more for the track but never mind.
Been a long time since I’ve been able to write an essay about performance modifications but feels good to sit here and chat for a while. Here’s some pictures to feast upon now, please enjoy and as usual, feedback is more than welcome!
Offline Olliewray
« Reply #162 on: January 20, 2015, 06:43:25 pm »
Awesome, love the 32 exhaust pic on first page
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #163 on: January 20, 2015, 08:38:44 pm »
Great write up - that's some serious waiting time you did there, but I'm sure she drives well now!
Do you know how long it took to fit the rear kit? Want to get mine done, as the front is all Superpro, but need to sort the rear at some point...
Just out of interest - which circuit are you doing for your first trackday?
Edition 30 - no. 1387
Offline th3_f15t
  • -Receive: 183
« Reply #164 on: January 20, 2015, 08:42:00 pm »
I'm still getting used to how she drives now, certainly not the same car I was driving a month ago! Feels totally different now.
Took about 2-3 hours alone to do the rear kit and it's fairly involved. Alex had to cut some of the bolts and things off as they totally seize up over time.
I'm going to an activity day at North Weald Airfield, it's a good place to get to know the limits of my nerves and car.
