Author Topic: *** All your Revo question's and answer's in here please. ***  (Read 41038 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: difference between Revo stg 1 and 2
« Reply #60 on: February 06, 2009, 12:07:48 am »
You can preserve your clutch quite a lot by not booting it at low revs in higher gears Gaz.
Stage II is less agressive than Stage I but it pulls longer and harder at the top end.
Stu...
Offline gazbutS3
« Reply #61 on: February 06, 2009, 12:32:35 am »
I do try not to pull to higher gear, the engine will produce the torque but you load the clutch. I learnt this lesson on my 8P S3.
But think about how much gets lost in the 4mo on the s3 it's massive so it should be ok running stage 2 but just use the gears more and be gentle in 6th
agreed, but not sure its as much as quoted sometimes, read a thread the other day stating it was 120bhp, I'm not havin that, it wouldn't be worth havin it, can't believe a std S3 puts 145bhp on the road, can you?
Cheers Stu, will give it a go for 50 quid I think
Offline em2evol
  • Let's Motorvate!
« Reply #62 on: February 06, 2009, 12:49:24 pm »
Hi everyone
Is there any way to get VW software updates without wiping off Revo?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Revo and software updates
« Reply #63 on: February 06, 2009, 12:50:23 pm »
Simple answer is no I am afraid   :sad:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #64 on: February 06, 2009, 12:58:15 pm »
REVO will replace the software free of charge however the dealer may make a small labour charge for the re installation.
Stu...
Offline em2evol
  • Let's Motorvate!
« Reply #65 on: February 06, 2009, 01:01:09 pm »
How will the Revo dealer know my car's been Revo'd if it gets wiped off?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #66 on: February 06, 2009, 01:06:08 pm »
If it's the same dealer then I'm sure they'll know, it'll also be logged at REVO HQ
Stu...
Offline em2evol
  • Let's Motorvate!
« Reply #67 on: February 06, 2009, 01:09:27 pm »
Ok cool, thanks :happy2:
« Reply #68 on: February 06, 2009, 08:59:35 pm »
Your revo dealer would have sent your vin and other details to revo hq at the time you got flashed.
Offline Sunglasses Ron
Revo Stage 2+ Ed30 vid..
« Reply #69 on: February 09, 2009, 11:21:54 pm »
« Last Edit: February 10, 2009, 06:51:08 pm by Greenouse »
Re: Revo Stage 2+ Ed30 vid..
« Reply #70 on: February 10, 2009, 09:38:26 am »
That is one seriously quick machine. It is vids like this that really make me miss my ED30  :sad:
Offline no golf clubs at all
« Reply #71 on: February 13, 2009, 11:40:26 am »
I am sure that my local dealer (revo) when I asked them to remove my map, set it up so that I would eat fuel...
Long story but desperately needed the car unrevoed and within the 30 days guarantee wanted a refund...the dealer argued with me stating that I was not giving them a good reason to remove it....ultimately I stuck to my guns that I was not happy with the power uptake, it was too aggressive and they renaged and gave me a full refund.
Since then MPG is around 23MPG. Can I go to VW and explain and ask them to reflash the ECU? if so, anyone any idea how much it would cost?
Offline GTIjames
« Reply #72 on: February 13, 2009, 11:58:29 am »
how long ago did this happen, if only recently then give it time as mpg is always thrown a bit when changing between stock and remap modes. reset the mpg and give it a good run to see if it improves.
if this has gone on for a week or so, then take it to your garage and they will look at it for you, but i would not mention the revo just say mpg seems to have dropped signif and you are a little concerned.  :happy2:
« Reply #73 on: February 13, 2009, 12:08:11 pm »
Its been since last November mate.....I would consider getting Revo back on but NOT through that dealer, their attitude wasnt the best,....admittedly I had a big part in their stance...however I was expecting some cooperation and was intending on returning to get it back later the next month....
If they had played ball I would have had the Forge on, the REVO and some springs and potentially upgraded brake pads....
I am out of warranty now...nothing to lose by stating exactly what happened and asking to get it reflashed.
I am at 34,000 was thinking of putting it in anyway for an early DSG service.....
« Reply #74 on: February 13, 2009, 03:01:48 pm »
did the dealer actually reflash your car with the stock code as it's quicker for him to just switch the revo map to "revo stock".
