Author Topic: DAB stopped working on my rcd510??  (Read 4440 times)
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
« on: December 26, 2013, 05:57:27 pm »
Hi Guys,
My DAB has suddenly stopped working on my RCD510.
I installed it a couple of months back and have had no issues..
Switched it on a couple of days ago and it just says 'no ensemble' below the station name and the no signal symbol.
I've checked the connection on the back and reset the station list.
Any idea's anyone? I've heard on here there's hidden muenu's that can be accessed.. Is this correct? How do you access them?
Thanks in advance!!
 :confused:
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
Re: DAB stopped working on my rcd510??
« Reply #1 on: December 26, 2013, 06:14:36 pm »
Sorry it's not a direct answer to your question; how did you install your DAB RCD510? Did you go the proper VW route with the aerial etc of just buy a windscreen aerial? SMB?
There are hidden menus, more so on the RNS510. Hopefully someone will be along to help you. :-)
Offline Gman30
« Reply #2 on: December 26, 2013, 08:08:45 pm »
I used the 'Kinetic' Arial from http://www.dabonwheels.co.uk -very helpful!
They can supply the adapters and everything you'll need.
Buy a few spare clips for pillar trims too as the headlining will need to be dropped!
Offline sootpig
« Reply #3 on: February 23, 2014, 05:46:35 pm »
 Gman did you sort the no ensemble  problem :happy2:
Offline Gman30
« Reply #4 on: February 23, 2014, 11:08:08 pm »
Yea it turned out to be the aerial at fault after alot of mucking around! The above where I bought it are saying I didn't use enough grease so my warranty is void! V angry as I used plenty of special grease that is designed for such applications! It was only on car 2 months!
