Author Topic: Quad Rear Lights / Skyline Mod using standard inner lens (NOT Valeo)  (Read 60730 times)
Offline G40will
Re: Quad Rear Lights using standard inner lens (NOT Valeo)
« Reply #30 on: January 08, 2014, 08:11:27 pm »
Thanks very much for doing the extra video mate!
I'm in two minds weather to do the quad lights mod whilst there apart :sad1: I do like the look of that mod but not sure if I can be assed to do it :popcornsoda:
It is all a bit of a pain in the bum but I like my projects and think the end result is worth it. The worst bit is separating the lenses so it would be the perfect time to do the quad mod. Up to you dude
That is a very good point! And I suppose I do need to do a bit of wiring in the boot lid after changing to a mk6 handle (wiring needs an extension)
I should just order the bits and do it!
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
  • Instagram & YouTube - mateyguv
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.0.html
« Reply #31 on: January 08, 2014, 10:18:43 pm »
 :jumpmove: :pomppomp: Do it!!!  :pomppomp:  :jumpmove:
I notice the wiring is different for the MK6 handle (3pins) when I did my reverse camera, any idea why?
Offline G40will
« Reply #32 on: January 08, 2014, 11:31:29 pm »
Mines just a standard mk6 handle, no camera.
It had the same connector, just the location of the plug stretched the standard wiring more than I would like.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #33 on: January 25, 2014, 03:16:04 pm »
Iv only just realised my led rings have resistors in the cabling. Were yours like this?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #34 on: January 25, 2014, 03:21:21 pm »
Answered by own question as they are the same. Did you detach the cable from the resistor and drill a bigger hole to fit the plug through aswell or did you take the plug off completely?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #35 on: January 27, 2014, 07:34:26 pm »
The ones I used had a connector before the resistor. I was able to carefully remove the wires from the connector and put though a 2mm hole i drilled in the lens then re insert the wires in the connector.
Offline v4rley
  • -Receive: 104
« Reply #36 on: January 27, 2014, 09:18:06 pm »
Well gave it a bash and pretty chuffed with the outcome! Still need to have a play with the final wiring and perhaps some led bulbs for the outers. Brightness is good match, just the halogen don't photo so well. Thanks for your guide it was great help and encouragement!!  :drinking:
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #37 on: January 27, 2014, 09:42:34 pm »
Looking good!!!  :congrats: The LED bulbs in the outers are really worth doing. I found the outers looked a little orange when compared to the LED rings I used on the inners.
« Last Edit: January 27, 2014, 10:13:54 pm by MateyGuv »
Offline G40will
« Reply #38 on: January 27, 2014, 10:05:04 pm »
I'm thinking about doing the led rings in my old lights and tinting them of course. Would I be able to have led rings in the outers and have them light up more under braking?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #39 on: January 27, 2014, 10:19:41 pm »
Iv never taken the outers apart so not sure what they look like inside. From what iv seen I think they are two halfs - each outer has two bulbs in them. It may be easier to re wire them so both bulbs light up under braking. It would look cool so I may need to get my thinking hat on
Offline G40will
« Reply #40 on: January 28, 2014, 09:19:30 am »
This is the only pic I have of the outer completely stripped down.
It has a similar cavity to the inners...
Offline v4rley
  • -Receive: 104
« Reply #41 on: January 28, 2014, 10:10:29 am »
Thanks am very pleased. Where did you get your led 1156 outer bulbs on bold-sport? and I right that a full set would be approx £50?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #42 on: January 28, 2014, 10:51:02 am »
May be possible then, not sure how you'd wire it though. Did the red lens have a divider in it or something simular cause when the brakes are on the brake light is a very defined half circle
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #43 on: January 28, 2014, 10:56:09 am »
Here is the link - http://www.bold-sport.com/store/index.php?route=product/product&path=43_39_57&product_id=268
It was about 50, look on eBay and you will find lower cost ones. Iv always been really happy with bold sport stuff and had no errors or issues so didn't mind paying a bit over the odds for an easy life. Just to confirm you will need a total of 4 bulbs so 2 packs of them
Offline G40will
« Reply #44 on: January 28, 2014, 01:37:43 pm »
Yes there is a diveder in the lamps silver backing part so I guess it would be difficult to get the ring in there. Would need some cutting to be done!
