Author Topic: Max wattage headlight bulbs  (Read 1515 times)
Offline Dj.Duffa
« on: December 31, 2013, 07:38:05 pm »
Any one know what the max wattage of headlight bulbs you can fit is?
Or how to work it out!
I'm looking into fitting slightly higher than 55wats but I don't want to be fluffing up the wiring etc!
Offline Edition_slim
Re: Max wattage headlight bulbs
« Reply #1 on: December 31, 2013, 09:18:36 pm »
I'd just go for a decent 55w bulb like an Osram Nightbreaker. If you start upping the W, then you increase the heat and can cause your lenses to glaze/crack.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: January 01, 2014, 01:02:02 am »
Pretty sure 55w is the highest legal wattage as well.
You would be better off fitting some quality bulbs as mentioned and also performing a wire/circuit check of your lights to ensure the full 12 volts are getting to your lights, as even a small impedence can reduce brightness huge amounts.
« Reply #3 on: January 01, 2014, 02:13:21 am »
you can get higher than 55w but not road legal and the heat can turn the reflectors in the lights a yellow colour which effects the beam pattern
http://www.phoenixautobulbs.co.uk/pr/ring-rally-sport-h7/
