Author Topic: Engine light after stage 2 with dp and cat **SOLVED**  (Read 5620 times)
Offline Aparoon
« on: September 23, 2009, 11:35:34 am »
I had my downpipe and sports cat fitted on Monday and have uploaded stage 2, as i went to work the other night i noticed that my engine light was on? The cars driving completely fine i only noticed the light as i pulled up, is this likely to be something to do with the new cat?
« Last Edit: September 26, 2009, 12:12:05 pm by Aparoon »
Edition 30 DSG, Revo 2+,BSH Intake, Autotech hpfp, Blueflame TBE,  Eibach Sportlines, Speedline Turini's GONE
Offline Aparoon
Re: Engine light after stage 2 with dp and cat
« Reply #1 on: September 23, 2009, 11:51:42 am »
I have just found on another search that the larger diameter dp and the lower cell cat can stop the temperature getting high enough which in turn causes the 02 sensor to throw a code, does that sound about right to anyone?
It says that i can clear the light via vag com if that is the case but it may continue to throw it unless i get the map tweaked, Im bf stage 2  :happy2:
Offline Aparoon
« Reply #2 on: September 23, 2009, 12:01:15 pm »
Thanks mate, I needed some reasurance lol  :happy2:
Offline Poppa Dom
« Reply #3 on: September 23, 2009, 12:06:48 pm »
Now go and get it mapped  :happy2:
Offline Aparoon
« Reply #4 on: September 23, 2009, 12:13:11 pm »
Ive got it mapped, im on bf stage 2, i just spoke to them and they said their software should cover this so im gonna stick the handset in and see if i can get the condes if there are any, wish i had a clue what i was doing  :scared:
« Reply #5 on: September 23, 2009, 12:16:05 pm »
Before recommending anything I would want to know what the actual fault code was that's causing the CEL.
It can come on for a lot of things but I drove around for several weeks on the standard map with dp and cat with no problems.
Once you get the codes post them on here and check http://wiki.ross-tech.com/index.php/Category:Fault_Codes.
Offline Aparoon
« Reply #6 on: September 23, 2009, 12:36:25 pm »
I have just got the codes using my bf handset (v useful), they are p0139 and p2195, they both relate to the os sensor  :happy2:
Offline Poppa Dom
« Reply #7 on: September 23, 2009, 12:48:12 pm »
Could be that a new sensor is in order if that is the case, but I am no expert.
« Reply #8 on: September 23, 2009, 01:14:00 pm »
I think I would be speaking to whoever fitted the exhaust.
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: September 23, 2009, 01:49:47 pm »
the guy who i bought my pipewerx exhaust off had the same problem also using bluefin stage 2.
ill find the link for you in a bit, but i believe one of the sensor bungs in the exhaust was blanked off for some reason which pipewerx explained and he drilled it through, solving the problem
Offline Janner_Sy
  • -Receive: 113
« Reply #10 on: September 23, 2009, 01:58:53 pm »
discription of the exhaust blank plate
http://briskoda.net/maintenance-performance/performance-down-pipe-question/138691/
discription of what might have caused CEL light on dash etc
http://briskoda.net/octavia-ii/random-cel-light/139597/
« Last Edit: September 23, 2009, 02:02:49 pm by simonskerton »
Offline Aparoon
« Reply #11 on: September 23, 2009, 03:52:01 pm »
Thanks for those replies and links. I think the issue was due to the fact that i drove home with the dp and cat on whilst running stage 1 which doesnt account for the sensor issues, i then uploaded stage 2 but it was too late by then. I have spoke to superchips and they say that stage 2 is setup to deal with the sensor issues so now i have cleared the codes the engine light has dissapeared and should not be an issue again  :smiley:
« Reply #12 on: September 23, 2009, 04:30:54 pm »
I can't agree with that. I drove with stage 1 and full Milltek dp and cat for months.
It was only after the Superchips RR day that I changed and since then I have done around 3 weeks with the standard map.
Whose dp and cat have you got? 100 or 200 CEL?
Offline Aparoon
« Reply #13 on: September 23, 2009, 04:38:55 pm »
Its a pipewerx dp with 200 cell cat. I dont know then either but the car is running fine, the light came on after the dp and cat was fitted and the dtcs related to the o2 sensor?? I will see if the light comes back on after when i drive to work...
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: September 23, 2009, 05:52:26 pm »
might be worth sending an email to pipewerx asking if oneo f the sensorholes is plugged, and if that could be the cause, it solved it with my DP
