Author Topic: 91Y or 94Y  (Read 3745 times)
Offline Meallbhan
91Y or 94Y
« on: January 10, 2014, 08:50:47 pm »
Evenin all
Its tyre time again and I just need two. Just now I have the Goodyear Eagle F1 Assemetric 2's fitted all round, in 225/45 17 91Y.  These I have found to be fantastic tyres in both wet and dry conditions and am tempted to bet them again.  My only grip is that I feel the tyre wall is a little soft, so can make the car a tad wobbly, even at 36, 37 psi.
Goodyear also make this tyre in a 94Y, a stronger tyre wall. I assume to be used if you are towing or really loading the car.
So I'm wondering if this will improve the wobbly feeling from the 91Y's.
What are your views?
Offline xjay1337
  • -Receive: 377
Re: 91Y or 94Y
« Reply #1 on: January 10, 2014, 08:55:03 pm »
Can you not get an XL one..? 94 would be better than 91..
I only buy XL tyres.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: 91Y or 94Y
« Reply #3 on: January 10, 2014, 10:42:25 pm »
get the xl version as the side walls will be a bit stiffer
Offline Meallbhan
Re: 91Y or 94Y
« Reply #4 on: January 10, 2014, 11:31:47 pm »
Me too, and yeap you can get the AS2's in XL' on 17's too :party::
http://www.camskill.co.uk/m54b0s16p109613/Goodyear_Tyres_Car_Goodyear_Eagle_F1_Asymmetric_2_-_225_45_R17_94Y_XL_FP_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_1_Noise%3A_69dB
That's a good price.
So how do these tyres feel with a stronger wall, is it really noticeable?  Does it make a harsher ride? Etc.
Offline 56OctyVRS
  • -Receive: 72
Re: 91Y or 94Y
« Reply #5 on: January 11, 2014, 11:33:20 am »
The main reason for xl tyres is so you can run lower pressures in them and still have stability.. They do not create a harsh ride at all. You only get that with run flats, as the tyre walls are almost like bricks.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: 91Y or 94Y
« Reply #6 on: January 11, 2014, 01:36:29 pm »
The XL's will be the 94Y.
Diesel Daily Hack.
