Author Topic: Diesel starting problems when hot  (Read 3775 times)
Offline George10
« on: January 11, 2014, 12:28:41 pm »
Hi,
Does Anyone know why my cars taking ages to fire up when warm ?
Start on one turn when cold so it's not the glow plugs. This is happened to a few people I know so something must need replacing.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Diesel starting problems when hot
« Reply #1 on: January 11, 2014, 12:58:26 pm »
Really common issue. I had it on my tdi too but just ignored it. I think its something to do with the crank sensor or something like that
Sent from my GT-I9300 using Tapatalk 2
Offline Matto
  • -Receive: 116
« Reply #2 on: January 11, 2014, 01:14:47 pm »
I think it can also be related to the thermostat aswell.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #3 on: January 11, 2014, 03:29:16 pm »
Most likely the crank sensor as said. Sometimes throws up a fault code and also occasional limp mode as it gets worse (when you're booting it usually).  If the battery is getting old this can also cause hot starting problems, as can the starter motor. These two issues are related to crank speed as there's a minimum rpm for the ecu to enable fuel injection. When hot the starter motor can give slow cranking speeds (as can the battery).
Thermostat wouldn't cause the hot start problem as it's purely mechanical so nothing to report to the ECU, although the temperature sensor possibly sensing incorrectly could be causing problems. However, the temperature is a red herring as it's usually the crank speed which is critical when the coolant temperature is above 70°c.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
« Reply #4 on: January 11, 2014, 03:35:42 pm »
can have issues with starter motor
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #5 on: January 11, 2014, 03:39:24 pm »
That's what I just said.  :P
« Reply #6 on: January 11, 2014, 03:47:04 pm »
well that will teach me to read previous posts :signLOL:
Offline George10
« Reply #7 on: January 11, 2014, 04:36:01 pm »
Thanks for all your comments. Anyone know how much a crank sensor is ?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #8 on: January 11, 2014, 05:26:41 pm »
About £80 - £90 or so I reckon.
Offline martin@gti.co.uk
« Reply #9 on: January 11, 2014, 07:16:14 pm »
Check advance timing. Could be water temp sensor. But as mentioned above..probably starter motor spinning bellow 250 rpm.. get a tuned starting map..cheapest solution or resistor on temp sensor..
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #10 on: January 11, 2014, 07:55:05 pm »
Mine was the crank shaft position sensor. VW did it for free i think
Offline xjay1337
  • -Receive: 377
« Reply #11 on: January 11, 2014, 07:57:22 pm »
It's nothing to do with any sensors 90% of the time.
It's starter motor not spinning the engine fast enough. After X seconds cranking it just dumps a load of fuel in, you might notice a bit of smoke is puffed out after starting.
It's also fuel/map related so after a remap the problem should be fixed as it just fires in more fuel earlier rather than waiting for the RPM to be reached.
New starter/battery/replacing any worn wiring/earths etc will also help.
Offline doylebros
« Reply #12 on: January 11, 2014, 10:30:35 pm »
Noticed this but the part is chassis number dependant just a guide!
http://www.ebay.co.uk/itm/VW-GOLF-AUDI-A3-OCTAVIA-LEON-1-9TDI-CRANKSHAFT-IMPULSE-SENDER-036-906-433-B-/280903993896
TPS price  for 036 906 433 B - £61.53 full retail inc vat
Also this is worth a read
http://www.rmitechnicalforum.co.uk/topic182-vw-golf--diesel-bkd---non-start-when-hot.aspx
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #13 on: January 11, 2014, 11:37:37 pm »
There are two versions of the crank sender as you say. Later ones are different and more expensive.
Offline G40will
« Reply #14 on: January 12, 2014, 02:09:10 pm »
My mk4 golf had hot start issues just before the starter packed up!
Just my 2pence :happy2:
