Same as the other 500000 threads on the topic.They would be OK.
Theres a massive thread in the general area about them
This seems to be the thread people are saying about. From what I can tell, light output is rubbish so you would need an. (Illegal) HID kit http://www.mk5golfgti.co.uk/forum/index.php/topic,56795.345.html
Light output is fine with mine, im happy with them.
Quote from: jbenekeorr on January 15, 2014, 06:34:27 pmThis seems to be the thread people are saying about. From what I can tell, light output is rubbish so you would need an. (Illegal) HID kit http://www.mk5golfgti.co.uk/forum/index.php/topic,56795.345.htmlThanks for the link mate, unsure about the illegal bit, I've used HIDs for years and from reading the VOSA guidelines which you can get on the web it makes it quite clear the legalities of them. http://www.transportoffice.gov.uk/crt/doitonline/bl/mottestingmanualsandguides/mottestingmanualsandguides.htm"Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system."The rest I believe is the same for any bulb in terms of beam aim etc.My two pence worth
Quote from: xjay1337 on January 15, 2014, 01:19:55 amSame as the other 500000 threads on the topic.They would be OK.Quote from: JoeDarKa on January 15, 2014, 07:26:17 amTheres a massive thread in the general area about themAs I mentioned I've been through a fair few threads, maybe I'm using the search function wrong as I'm getting threads up from 2011 right back to 2008 I had a niggly feeling this question may have been asked once or a few thousand times!Any links then guys?
Quote from: usmangti on January 15, 2014, 12:13:29 pmQuote from: xjay1337 on January 15, 2014, 01:19:55 amSame as the other 500000 threads on the topic.They would be OK.Quote from: JoeDarKa on January 15, 2014, 07:26:17 amTheres a massive thread in the general area about themAs I mentioned I've been through a fair few threads, maybe I'm using the search function wrong as I'm getting threads up from 2011 right back to 2008 I had a niggly feeling this question may have been asked once or a few thousand times!Any links then guys?The search function is a bit weird on this forum...try going to Advanced and limiting the age of the results (change the 9999 days to 365, or whatever). Might help.
