Author Topic: Is 30 mpg achievable?  (Read 4534 times)
Offline Phillyf21
« on: January 13, 2014, 02:15:51 pm »
Hi all,
I know there are too many variables to consider, but do you think 30 mpg is possible from the following scenario:-
50 mile round trip consisting of 35 miles of moderate motorway traffic and 15 miles of free flowing A roads, all driven pretty sensibly?
I leave the non-sensible driving for weekends  :evilgrin:
Phil
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Is 30 mpg achievable?
« Reply #1 on: January 13, 2014, 02:21:39 pm »
Depends on driving style. Try it and see?
Offline edewer
« Reply #2 on: January 13, 2014, 02:32:00 pm »
I wouldve thought so. I do a mix of A roads and motorway to work (30 miles or so) and i can get anywhere from 37 on a good run, down to 22 because I was in a serious rush this morning!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: January 13, 2014, 03:41:12 pm »
Yes. I could get mid - high 30's on a run like that. Correct Tyre pressures, light right foot, coasting down to junctions using engine braking and a clear run without traffic lights all help to get great MPG  :happy2:
  • -Receive: 427
« Reply #4 on: January 13, 2014, 04:19:14 pm »
^^^^ Sounds about right. I usually get 34 mpg ish at cruising speed (60mph ish) and no more than 23mpg around town in my Eddy.
Your not rushing anywhere NEAR enough, I expect mid teens if I'm in a PROPER hurry!  :evilgrin:
Offline cageman86
« Reply #5 on: January 13, 2014, 04:39:20 pm »
I do 25 miles to work and 25 back, about half is on the motorway the other half around town, if I drive at 70 on the motorway and the traffic in town isn't too bad I can easily get 30-35 MPG BUT and its a huge BUT it starts drinking if you get a bit of a heavy right foot and if your sitting around in traffic and in low gears its not too clever, at very worst on my journey to work I get about 24-27 mpg but I use the motorway, before when I worked in town I would struggle to get above 25-27 driving like a granny, my cars stage 1 R-tech with no other mods, and it is definitely better since its been mapped BUT and again this is a gigantic BUT use the power or drive it cold or do short journeys it will drink fuel! All good fun though!  :driver: :driver:
Offline Phillyf21
« Reply #6 on: January 13, 2014, 05:18:30 pm »
Great answer,  thanks. I will also be purchasing the r-tech stage 1 with a carbonio intake, cant wait.
Offline Broomy
  • -Given: 18
« Reply #7 on: January 13, 2014, 06:50:59 pm »
20 miles to & from work, village & 60mph road mix only just got the car last Saturday.
Offline Deago
« Reply #8 on: January 13, 2014, 06:59:48 pm »
I quite often hit mid to high 30's even on the shorter journeys
Offline xjay1337
  • -Receive: 377
« Reply #9 on: January 13, 2014, 07:16:49 pm »
Trip and range remaining, no fuel light on
 :jumpmove:
Offline edewer
« Reply #10 on: January 14, 2014, 07:38:26 am »
That another of your dodgy photoshops again Jay? (Minus the penises drawn in paint?)
Offline xjay1337
  • -Receive: 377
« Reply #11 on: January 14, 2014, 09:12:37 am »
 :grin: :signLOL:
This time no photoshop was involved! I can tell from having seen a few shops in my time.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #12 on: January 14, 2014, 09:47:58 am »
I had a commute similar to the OP's, and I averaged 28.5 to 29 mpg when driving as a zombie...and 26.5 to 27 mpg when alive.  :grin:
I found, when my mileage began dropping over the last 7 years, that the MAF was going bad, the coils were going bad, or winter's crappy fuel had arrived.
So, one needs to keep their mkv firing well to achieve top running mpg.
All that will effect the mileage are going to be:
plugs
coils
failing maf or O2 sensor
fouled injectors
running rich - vcds group 33
gummed up intake ports
old oil
using 5w when 0w oil is better for winter mileage
fueling not running optimally...etc.
Offline xjay1337
  • -Receive: 377
« Reply #13 on: January 14, 2014, 10:39:31 am »
0w oil???
I would not recommend that...
Especially when the engine is at temperature the cold weight of the oil has no bearing on fuel economy.....
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #14 on: January 14, 2014, 10:54:16 am »
I run 0w40 all of the time. It's for start up and idle until reaching operating temps where it saves on mileage.
OP, what is your cold tire pressure currently at? Do you check it early morning before the sun hits the tires or warms the air?
Quote from: Mobil 1 Oil
Q: Does 5W-20 Motor Oil Offer Fuel Economy Advantage over 5W-30?
A: You should probably continue to use the viscosity recommended by the OEM (Original Equipment Manufacturer) which is a 30 grade. We have introduced two products: Mobil 1 0W-20 and 0W-30 Advanced Fuel Economy. We recommend you try Mobil 1 0W-30 Advanced Fuel Economy as a replacement for the 5W-30 you are currently using.
« Last Edit: January 14, 2014, 11:08:24 am by ROH ECHT »
