Author Topic: Is 30 mpg achievable?  (Read 4531 times)
Offline Phillyf21
Re: Is 30 mpg achievable?
« Reply #15 on: January 14, 2014, 11:16:34 am »
I run 0w40 all of the time. It's for start up and idle until reaching operating temps where it saves on mileage.
OP, what is your cold tire pressure currently at? Do you check it early morning before the sun hits the tires or warms the air?
Currently dont own a mk5, i'm hunting for one as we speak. Just asking the question regading mpg really. Currently drive a s60 d5 which will still get 50 mpg with 4 flat tyres  :laugh:
Quote from: Mobil 1 Oil
Q: Does 5W-20 Motor Oil Offer Fuel Economy Advantage over 5W-30?
A: You should probably continue to use the viscosity recommended by the OEM (Original Equipment Manufacturer) which is a 30 grade. We have introduced two products: Mobil 1 0W-20 and 0W-30 Advanced Fuel Economy. We recommend you try Mobil 1 0W-30 Advanced Fuel Economy as a replacement for the 5W-30 you are currently using.
Offline SkyJawa
« Reply #16 on: January 14, 2014, 11:22:53 am »
As per other posts, got 37.6 shown last night in the rush hour to Maidstone coming back for the whole trip it was 34.5 as managed to get a bit of a heavier foot coming back  :wink:
Better than my 330d at the moment showing just 34!!!!
Or perhaps I bought a TDi by mistake lol  :grin:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #17 on: January 14, 2014, 11:34:34 am »
Dope! Yes, you will likely get very near 30mpg ±
Offline john87
  • -Receive: 53
« Reply #18 on: January 14, 2014, 12:12:26 pm »
I think the mpg indicator in the mk5 should be read with a pinch of salt, as on my daily commute mines would often read between 33 and 36mpg, whereas my current mk6 R indicates between 29 and 32.
I get exactly the same number of miles to 20 quid as I did in the GTI..
Offline xjay1337
  • -Receive: 377
« Reply #19 on: January 14, 2014, 12:25:30 pm »
Maybe in very very cold climates, in the UK it will provide less protection against 5w.
While I may change top end W depending on application (I ran 5w40 on my old PD 1.9 tdi) to offer extra protection, I noticed ZERO difference in MPG between that and the 5w30 that it WAS serviced with. I don't see oil as a way to improve fuel efficiency!! Especially when wind direction and tyre pressures (or even tyre brand) can effect far more...
And certainly at the expense of my engine I am not going to start running a 0 weight oil.. that's basically water. And I would recommend no-one else in our climate does that either. In Canada over winter I think yes it would have it's place absolutely but not here.  :happy2:
Offline Rob.
« Reply #20 on: January 14, 2014, 12:33:58 pm »
I've managed 41mpg indicated in my Jetta TFSI on a 160 mile run (mostly motorway)...2 people plus luggage too.
Offline Twiggy
« Reply #21 on: January 14, 2014, 12:46:01 pm »
I got 38.6mpg on last year trip to Goodwood FOS, two people plus camping equipment, food and lots of Beer.
the trip was around 500 miles give or take.
Did it the year before in … dare i say it… a Focus ST and got 34mpg.
Just to put this in there, Golf is faster and more economical, also handles better but the exhaust pops of the ST are pretty sweet.
please note that on the drive down i was between 60-70mph and was driving carefully.
Fuel used was Vpower.
2005 mk5 R-tech custom stage 1
Offline nelmser
« Reply #22 on: January 14, 2014, 06:26:00 pm »
I think reaching 30 mpg is easy.  I can achieve it on a 30 minute trip (50% dual carrageway and 50% town), and I like to rag it around a bit!!
On the sort of journey you're describing, if careful I'm sure you could hit high 30s  :happy2:
2006 MK5 GTI 2.0
Offline Deago
« Reply #23 on: January 14, 2014, 06:27:58 pm »
If you're careful enough you can get pretty good mpg out of the gti. I drove to Heathrow casually and got 41.5  :party:
Offline xjay1337
  • -Receive: 377
« Reply #24 on: January 14, 2014, 06:53:34 pm »
You'd be surprised what sort of MPG you can get if you drive careful :)
Offline Frodo-anni
  • -Receive: 45
« Reply #25 on: January 14, 2014, 09:45:23 pm »
22 mile journey to work, 14 miles on motorway - returns 36-38mpg each morning.
Heavier traffic in an evening, but can see 31-33mpg on way home. As mentioned above if i get stuck in traffic it does drop 24-26mpg.
mk5 GTI Edition 30 DSG No0391
Offline D Squared
  • -Given: 41
« Reply #26 on: January 15, 2014, 12:14:14 pm »
interesting post, i'm new to my GTi, and i do about 10miles each way to work, town and country roads, and get low 30's driving like an old granny....
2007 5dr GTi
Offline Phillyf21
« Reply #27 on: January 15, 2014, 02:47:50 pm »
Ok fellas from all the previous posts I understand that 30 mpg is easy achievable. Just need the car now, can't decide on a 05/55-06 higher milage for £5-5.5k or bite the bullet and get 56-07/57 lower milage example for £7k. The missus is on my case as I was meant to be buying another diesel though, so I'll probably end up with a older higher milage example.
Thanks for all your help.
Phil
Offline Jonathon555
« Reply #28 on: January 16, 2014, 07:21:26 pm »
30 mpg from ed30 yes
But you have to go steady
