Author Topic: Change off wheel and ets and that  (Read 661 times)
Offline Tommyt90
« on: January 14, 2014, 03:34:41 pm »
At the minute I've got some 3sdm's 8.5 front et 42 rear 9.5 et40 with 215/35 front and 225/40 rear. I've bought some bbs ch's for cheap 8 front and 9 rear. Et 42 all around. Gonna put 205/35 front and 215/40 rear. But to get the same stance as the 3sdms what spacers would I need.
Offline Deago
Re: Change off wheel and ets and that
« Reply #1 on: January 14, 2014, 04:07:40 pm »
not much 10mm would bring it pretty close
Offline Tommyt90
« Reply #2 on: January 14, 2014, 04:41:41 pm »
I was thinking 10 but unsure. Would you have use a hub centric spacer
Offline Rob.
Offline Tommyt90
« Reply #4 on: January 14, 2014, 05:46:20 pm »
Cheers mate
Offline jaffa
  • -Receive: 44
« Reply #5 on: January 14, 2014, 07:06:33 pm »
6mm will get the same fit as your 3sdms  :happy2:
Offline Tommyt90
« Reply #6 on: January 14, 2014, 07:15:24 pm »
Would I need hub centric or just longer bolts
Offline xjay1337
  • -Receive: 377
« Reply #7 on: January 14, 2014, 07:27:21 pm »
No, you will need hubcentric spacers (to avoid wheel wobble you get with standard flat faced spacers) and bolts which are 6mm longer.. so you'd need to buy 33-35mm wheel bolts and hubcentric spacers.
While the edge of the wheel will sit the same you'll never the same look with a 9 on the back instead of a 9.5
Offline Tommyt90
« Reply #8 on: January 14, 2014, 08:12:03 pm »
I think ill bang them on and see how they look before I buy spacers. Sounds to much messing about for 6 mm :-/
