Author Topic: Retrofit MK5 Golf "AUX Switch"  (Read 3377 times)
Offline Shocker
« on: January 14, 2014, 07:30:54 pm »
Hello all,
I am planning to carry out this mod in my golf. Wanted to get some opinions as I'm no professional.
So... It all began when I saw this switch:
http://www.ebay.com.au/itm/VW-AUX-SWITCH-CABLE-GOLF-MK6-RCD510-RCD300-RCD310-NEW-VW-OEM-5KD-035-724-/161027638802?nma=true&si=biaE%252FUHlLUiGtVMnFuBl8p7%252F0Nc%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
I have an RCD300 in my car so I know I can't use this item out of the box. After looking into it a little, I came across this:
http://www.ebay.com.au/itm/190729178952?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Do you think I would be able to drill out the existing jack on the switch and push this one through it? Or is it wishful thinking?
I have seen another retrofit where the 3.5mm jack is constantly exposed but not a fan of it. I'm buying the connects 2 as the unit then attach it to the switch via the cable above.
What do you guys think??
Offline xjay1337
  • -Receive: 377
Re: Retrofit MK5 Golf "AUX Switch"
« Reply #1 on: January 14, 2014, 07:34:16 pm »
I'm sure you can use the other OEM jack on your car it may just need some different wiring.
All the VW Mk5/Mk6 plugs are the same on the back of the unit as you can switch them about willy-nilly.. It also says it's for the RCD300..?
Offline Shocker
« Reply #2 on: January 14, 2014, 07:43:02 pm »
Yes it does. However, it requires me to have the RCD300 with the silver buttons. Unfortunately mines are all black.
Offline xjay1337
  • -Receive: 377
« Reply #3 on: January 14, 2014, 09:10:37 pm »
Why do you need to have the silver buttons?
There's like, no functional difference in the headunit, plugs on the back are the same, presumably this plugs into a part of the CD changer port and tricks the car into using the multi CD changer menu as the Aux in.. ?
Offline Shocker
« Reply #4 on: January 14, 2014, 09:50:02 pm »
It is because of the description on this sellers description that put me on the DIY tangent.
http://www.ebay.co.uk/itm/VW-AUX-SWITCH-AUX-CABLE-for-RCD510-RCD310-RCD300-GOLF-MK6-Bora-Sagitar-Tiguan-/161083078753?pt=UK_In_Car_Technology&hash=item25814cb861
"Many Customer had the wrong expectation on this item. Please note it is AUX Jack without AUX enable function."
Due to the above I was considering the connects 2 and then mod the switch for a slick finish and no sticking out.
Offline martin@gti.co.uk
« Reply #5 on: January 14, 2014, 09:54:47 pm »
Tried it, it doesnt work mate. You need another module inbetween... you can code your radio to have via long coding AUX but it wont work.  but worth a try for this bucks.. :signLOL:
Offline Shocker
« Reply #6 on: January 14, 2014, 10:10:50 pm »
Yeah that's what I read on the tinternet. That's why considering the connects 2 unit. However wanted to know if it would be worth drilling right through the aux switch and have the audio wire route through the switch for the neat look.
Offline xjay1337
  • -Receive: 377
« Reply #7 on: January 15, 2014, 10:44:50 am »
Very odd indeed.
If it's true that you need another box inbetween then you could most likely do a teeny bit of wiring and mod it so the proper Aux controller simply goes to the Aux port that you have linked to.
Would be pretty simple really.
Offline Shocker
« Reply #8 on: January 15, 2014, 06:46:42 pm »
Very odd indeed.
If I could get some advice on how I could go about doing this I would appreciate it very much.
