Author Topic: Strut mounts removal help needed :(  (Read 6127 times)
Offline Andy1994
« on: January 17, 2014, 05:35:54 pm »
Fitting my springs today, rear was a doddle done in 15 mins, moving on to the front the three bots holding the strut at the top are spinning and have broke free from the mount, is there anyway to remove these apart from using a angle grinder
Offline biffobear
Re: Strut mounts removal help needed :(
« Reply #1 on: January 17, 2014, 06:30:49 pm »
No
Offline Andy1994
« Reply #2 on: January 19, 2014, 12:58:54 pm »
any help on this would be appreciated
Offline G40will
« Reply #3 on: January 19, 2014, 02:05:38 pm »
Just been doing the same job on mine and noticed that the top mount has nuts underneath so if yours is spinning then it may have broken loose from the mount.
It looks like a 13mm
Have a look under the wheel arch up into the top mount area and you'll se what I mean.
Offline Andy1994
« Reply #4 on: January 19, 2014, 02:11:46 pm »
yeah seen that cant get a socket on to it and not holding vice grips either
Offline biffobear
« Reply #5 on: January 19, 2014, 02:25:42 pm »
Told you, grinder, nut splitter, or hammer & chisel.
Offline martziniuk
« Reply #6 on: January 19, 2014, 03:30:13 pm »
I used a hacksaw on one of my bolts, the other stuck one I managed to get vice grips from underneath. A 13mm socket won't fit as they're a sort of oval nut.
Offline JigBake
« Reply #7 on: January 19, 2014, 09:22:03 pm »
This happened to me. There are a few ways to go about it. I personally tried avoiding doing any damage to the paint. I positioned the hacksaw blade underneath the head of the bolt and spun it with an impact gun (or drill) until the blade cut through. Problem solved. No paint on the struts was harmed in the process.
« Last Edit: January 21, 2014, 06:03:51 am by JigBake »
Offline Andy1994
« Reply #8 on: January 19, 2014, 10:02:56 pm »
thats a good idea did it take long?
Offline JigBake
« Reply #9 on: January 21, 2014, 06:03:28 am »
Seconds
Offline iian
« Reply #10 on: November 29, 2014, 01:46:00 pm »
This is bloody genious.
Thanks man, you just saved me from wrecked the place with a grinder
