Author Topic: RCD510 DAB Help???  (Read 624 times)
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
RCD510 DAB Help???
« on: January 17, 2014, 06:22:09 pm »
Hi all,
Anyone on here a DAB guru?
Im having problems with mine and wondered if anyone has experience with them??
Installed before christmas with no issues but now I can hardly receive any stations and its very patchy!!
 :confused:
Offline TeighlorD7
Re: RCD510 DAB Help???
« Reply #1 on: January 17, 2014, 07:01:01 pm »
I've just fitted one, got a window mounted aerial and fitted it. I get a few channels but most often than not no signal at all, still need to get and electrical friend to connect the 12v wire. But I did hear that the unit can power the aerial itself. Confused but I'll see what it's like after connecting to power
Offline Gman30
« Reply #2 on: January 17, 2014, 07:08:21 pm »
Yea, I avoided anything but a roof mount because I wanted good reception. I have the kinetic stubby and have a power feed coming from the 12v socket in the boot.
When I first installed it was fine but since we've had this bad weather its stopped receiving stations!
I can get bbc stations in certain area's but its very hit and miss and lost all my local and other national stations.
Checked wiring and thats fine too!
Very annoying!
Offline MikeA
« Reply #3 on: January 18, 2014, 09:24:29 pm »
I used the stick on windscreen aerial and have had no issues even up north in the highlands.
something like this   http://www.ebay.co.uk/itm/AutoDAB-AD-2-Glass-Mount-Patch-Antenna-DAB-Car-Radio-Aerial-Antenna-/251157349695?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item3a7a25053f
Had Dab in my company golf and this aerial is as good as the factory fit aerial, in my opinion  :happy2:
Current Mk7 2016 5dr GTi Clubsport Edition 40 DSG - No. 403
Tornado Red, Dynamic Chassis Control, Rear View Camera and 19" Brescia Alloys
Previous MK5 2007 3dr Edition 30 Manual - No. 376
Black, Rear parking sensors, Winter pack
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #4 on: January 18, 2014, 10:01:17 pm »
I had a DAB in my mk5, first with a stick on window one but reception was patchy (Essex/herts border) so changed to a polo dab roof mounted aerial, which is the same size and shape base as the normal aerial so just switched over and ran an extension fakra cable to the unit - no power needed as unit supplies it
Offline TeighlorD7
« Reply #5 on: January 19, 2014, 12:57:22 pm »
I bought that aerial too, did you connect the 12v wire or just leave it loose?  Might it be worth taking the trim off again and checking if it has been properly earthed?
