Author Topic: S3 Control arm Bushes - Worth the upgrade?  (Read 9575 times)
Offline GTI-Ross
  • Learning All The Time :)
« on: January 17, 2014, 08:53:12 pm »
Hey guys, is it worth upgrading the standard MK5 / MK6 control arms bushes with new S3  control arm bushes for £40, or save a bit more and get WALK?
Also whilst your here, are the S3 Alloy control Arms a decent upgrade and good value at £100?
« Last Edit: January 17, 2014, 08:57:02 pm by GTI-Ross »
Offline martziniuk
Re: S3 Control arm Bushes - Worth the upgrade?
« Reply #1 on: January 17, 2014, 09:34:08 pm »
I have the solid TT ones which are a massive improvement over stock. Don't the S3 bushes have slight voids in them?
Also consider the super pro anti lift kit.
Offline flashp
  • -Receive: 65
« Reply #2 on: January 17, 2014, 10:00:24 pm »
If you fit the alloy arms from the S3 at the same time you'll get a slightly improved geometry and a weight reduction. WALK may be the better option, I never tried standard bushes so couldn't comment on them.  :happy2:
Gone but not forgotten :-)
Offline Trekmeister
  • Golf GT 140
Re:
« Reply #3 on: January 17, 2014, 10:04:02 pm »
Are the alloy arms a straight swap. I was under the impression they cost more than £100?
Offline GTI-Ross
Re:
« Reply #4 on: January 17, 2014, 10:07:38 pm »
They are a nearly new set (second hand) - so not from dealer
Offline OEM+ DUB
« Reply #5 on: January 17, 2014, 10:21:01 pm »
I undertook this modification to my 2005 GTI DSG summer last year and have been really pleased with the upgrade.
I fitted brand new S3 alloy wishbones that came complete with the console bushes.  The weight saving over the standard cast steel wishbones is significant as a starter for 10, improving unsprung weight and therefore the quality of the ride, and the solid S3 console bushes are a notable improvement in terms of steering/handling precision without any compromise in terms of noise, vibration or harshness.
Hope this helps.
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline GTI-Ross
« Reply #6 on: January 17, 2014, 10:46:14 pm »
Hope this helps.
Yeah thats helps, so if i could get get S3 arms and bushes for £130 - £140 worth the money?
Offline martziniuk
« Reply #7 on: January 17, 2014, 10:53:28 pm »
Hope this helps.
+ a complete geometry setup.
Offline Matto
  • -Receive: 116
« Reply #8 on: January 17, 2014, 10:57:53 pm »
You could also add Superpro ball joints aswell to allow you to run abit more camber. This is what I'm planning sometime this year along with the S3 alloy arms. I already have the Superpro Anti Lift kit fitted.
Offline rob_e
  • 2012 vRS Octavia
    • vRS blog on Pistonheads
« Reply #9 on: January 17, 2014, 11:21:04 pm »
s3 arms and console bushes won't affect your geometry.  TT arms will, but s3 arms are the same dimensions as a regular gti/vrs I believe.
I had TT arms previously but now run s3 arms and bushes with superpro camber adjust ball joints.   The arms give you a weight saving, the bushes are stiffer (non voided) and with adjustable camber ball joints you can run whatever geo you want.   It's a very good setup.
I got my TT arms from a breaker, but the s3/cupra arms i have now were bought new - i got these from AKS, can't remember exactly but I think they were only about 110 each (arm + console and bush).
Offline xjay1337
  • -Receive: 377
« Reply #10 on: January 17, 2014, 11:23:13 pm »
Yes the Super pro Ball joints are a forthcoming upgrade for me too. The extra camber will mean I can run a more aggressive fitment.
I have the solid TT bushes in my consoles and they are very good. To be honest not having tried the WALK kit I can't really compare but price per £ upgrade the TT console bushes on their own would make a huge difference.
The biggest problem with a Mk5 in my opinion is how sensitive it is to Camber changes so I would hope the WALK kit can help that ... but hey.
Offline GTI-Ross
« Reply #11 on: January 17, 2014, 11:27:26 pm »
whilst we are talking set ups, does anyone have a wheel alignment print out I could look at. Im looking to get one done soon but I have no idea what values are good for fast road set up
Offline Matto
  • -Receive: 116
« Reply #12 on: January 17, 2014, 11:34:27 pm »
This was mine after having springs, SALK and rear ARB fitted. Alex did the geo setup.
Offline GTI-Ross
« Reply #13 on: January 17, 2014, 11:52:37 pm »
I wish i knew if that was the kind of set up i want or need.   :chicken: :ashamed: :chicken:
Offline Matto
  • -Receive: 116
« Reply #14 on: January 18, 2014, 12:00:37 am »
I think this is very close to stock setup which I'm told is good out the box. Obviously if you add some of the mods you're thinking of/suggested above it will allow you to play with the geo to however you want. I find the handling of mine currently very good but believe it could be made even better.
