Author Topic: Pressure washer advice and discount advice.  (Read 1827 times)
Offline Human Joist
« on: January 18, 2014, 09:37:08 am »
Morning all. Have decided to get a pressure washer as I need to clean patio but also want to start and use it on the car now the grit and rubbish is on the roads. Looking to get a snow foam lance too as heard good things about them. I am informed that nilfisk is the one to go for. Just wondered if anyone has a good model to aim for (not spending the earth) and a discount code maybe.
Offline DanMaytee
Re: Pressure washer advice and discount advice.
« Reply #1 on: January 18, 2014, 09:57:04 am »
http://www.cleanstore.co.uk/products/Product.asp?ID=7506
I have this and it's absolutely perfect  :smiley:. Brilliant price as well :happy2:.
Offline Human Joist
« Reply #2 on: January 18, 2014, 10:52:25 am »
Cool. Is the foam sprayer that's included a snow foam lance or is that something I need to buy separately
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #3 on: January 18, 2014, 01:47:41 pm »
Cleanstore is the place to get the cheap versions
Depends on your budget and mentality to buying stuff , i don't like to buy twice and bought a Karcher HD 6/13 C PLUS which was £430 , has variable pressure which is the reason i bought it and the fact it is made to run and run all day every day
I have had three cheap washers due to my son using them more than me , they are all broken and i would always advise buying the best quality and always buy a better one than you actually need  :innocent:
Offline Human Joist
« Reply #4 on: January 18, 2014, 01:52:03 pm »
Found this one from homebase. Seems quite good. Hard to tell the difference between the one detailed above and this one. Any one able to comment
And is a former bottle the same as a snow foam lance thingy
« Last Edit: January 18, 2014, 01:54:25 pm by Human Joist »
Offline DanMaytee
« Reply #5 on: January 18, 2014, 03:57:05 pm »
The homebase one seems good but I'd just go for the cleanstore one.  I've had one for two years from them now.  It gets used twice a week at least and has never let me down :).
The foam bottle can be used for snow foam and I actually use it myself for that.  Although it's not great it does the job.  You can always pick up a better lance for around £40 if you're not keen on it once you have tried it.
Offline scooba
  • -Given: 18
« Reply #6 on: January 18, 2014, 08:14:06 pm »
I like Garrard ,don't like buying twice I have had two Karchers die on me !,
Purchased a Kranzle 1152 TS T  and Kranzle snow lance washed three cars with it this morning it has variable pressure  and weighs in at 32kg  it is so solid and well made but was expensive at £599  ( cheap for a Kranzle bought using a 15% discount code )
By a Professional version as I was told all K version Karchers will fail  if used to often
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #7 on: January 18, 2014, 08:21:23 pm »
I've got a Krapper Karcher and it's been flawless in 5 years plus... I tell a lie, a seal split which cost 10p to replace...
I wouldn't advise using their Snow Foam lances though, been there, and the CYC Snow Foam Lance is way better, giving a lot thicker coverage. :happy2:
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #8 on: January 18, 2014, 09:08:09 pm »
I have one the same ( or very similar can't remember the model exactly) and been great. Did manage to split a hose but cheap fix, plus with those new reels even better. I also bought a proper snow foam lance which I feel is well worth the cash. Helps get rid of grit and road dirt - plus it's great fun  :grin:
