November 26, 2024, 08:25:29 pm
All Things Mk5
Mk5 General Area
Losing washer fluid?
Topic: Losing washer fluid? (Read 671 times)
micaerin
Always Involved
-Given: 19
-Receive: 13
January 19, 2014, 02:00:37 pm »
Hi guys seem to be losing washer fluid very quickly, is there a common place that it leaks from, or is it a case of taking out the bottle and replacing. if so anyone got a walkthrough for this?
Thanks in advance
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: Losing washer fluid?
Reply #1 on:
January 19, 2014, 02:04:47 pm »
front bumper will need to come off
I suspect that it may be one of the hoses has a leak
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
micaerin
Always Involved
-Given: 19
-Receive: 13
Reply #2 on:
January 19, 2014, 02:08:33 pm »
Really!
Cheers Eddie
Scottymon
-Given: 83
-Receive: 125
UnNaturally Aspirated
My Ride:
Reply #3 on:
January 19, 2014, 02:14:49 pm »
Mine leaks if it's over a certain level, I suspect a crack in the reservoir, here's a DIY of taking the bumper off:
micaerin
Always Involved
-Given: 19
-Receive: 13
Reply #4 on:
January 19, 2014, 02:25:03 pm »
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
If you're smart in this world they call you crazy
My Ride:
Reply #5 on:
January 19, 2014, 04:03:00 pm »
I wouldn't of thought it'd be a cracked bottle, probs the big O ring rubber seal that the pump is pressed into on the bottle. Might be a weak seal or the pump has some how wormed it way out of the seal slightly causing the leak.
Last Edit: January 19, 2014, 04:05:09 pm by Chris92
Viking
Won't Shut up.
-Given: 17
-Receive: 47
Reply #6 on:
January 19, 2014, 04:16:58 pm »
Mine leaks and loses fluid every couple of days. Summat I'm gonna have to look into at some point.
Cheers for the info.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
All Things Mk5
Mk5 General Area
