Author Topic: DSG oil and filter change  (Read 1734 times)
Offline Madman1886
« on: January 21, 2014, 08:14:15 pm »
Ive just been informed by my VW garage that my DSG is due its oil and filter change. I was wondering if anyone has done this themselves (im sure some of you's have lol ) and was wondering if its an easy job or any special tools required. I'm pretty handy with the spanners and was wanting to give it a go myself. Also anyone know the part numbers for the proper oil and filter and rough price of the parts.
Cheers in advance!!! :jumpmove:
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: DSG oil and filter change
« Reply #1 on: January 21, 2014, 08:29:33 pm »
There's a couple of different DGS filter / gearbox types, and the oil is about £20 per ltr as it's specific stuff.  Basically, if you can get your dealer to do it for £170 or so I'd not bother getting dirty. From memory it involves dropping the oil out, removing the airbox and removing the filter which is sited underneath it, replacing the filter, filling with oil until it overflows. Connect VCDS and run the engine up until the gearbox fluid hits a specific temperature while the excess runs out of the overflow/drain hole, then refit the sump drain plug. All a bit of a chew on really.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline doylebros
Offline Human Joist
« Reply #3 on: January 21, 2014, 09:22:11 pm »
Following on the above from Viking. Once all that is done you then need to a settings reset on the box. The oil and filter cost me almost £100 and that was discounted from a mate at VW. If your midlands my best made is a Indy in Worcester and will do it for around £140-£150
Offline Frodo-anni
  • -Receive: 45
« Reply #4 on: January 21, 2014, 09:39:04 pm »
For the small price differnce i'd stick with VW then if you have DSG issues, you should have more luck of goodwill and assistance.  :happy2:
mk5 GTI Edition 30 DSG No0391
Offline Madman1886
« Reply #5 on: January 25, 2014, 10:57:04 am »
cheers guys, think ill just give it to VW as they're quoting 170 for the job, for 20 quid or so they can have the hassle lol
