Author Topic: Mk6 climatronic install into mk5  (Read 18969 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Mk6 climatronic install into mk5
« Reply #15 on: November 03, 2014, 05:53:08 pm »
I'm about to do this and reading the various how to threads (posted above).
My car is  2006 GT TDI.
Can someone confirm the pin swap on connector A (black), as I've read conflicting information:
Is it:
Extract Pin 16 and Pin 20. Put pin 16 into pin 20 slot, leave pin 20 loose. May have to cut / change the pin connector as its a different size?
(So pin 16 moves to pin 20)
OR
Extract Pin 16 and Pin 20. Cut the end off pin 20. Splice into pin 16, put back into pin 16 slot.
Tape the bare end of 20.
(So 16 & 20 both goto pin 16, pin 20 is now empty).
If that doesn't work, try the swaps mentioned regarding plugs B / C?
@paulmk5gti what did you do, your car is same year as mine so will hopefully be the same.
EDIT: Found the answer in this thread:
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/9170-climatronic-screen-4-print.html
Now to work out the air quality sensor, again it doesnt seem clear on where the 3 pins goto:
Quote
Quality Sensor Wiring (OPTIONAL if you bought the module that handles it):
On C Connector (black):
Pin 1 from Quality Sensor to Pin 20 (which we replaced by Pin 16 on Climatronic, remember?)
Pin 2 from Quality Sensor is Ground goes to Pin 19
Pin 3 from Quality Sensor to Pin 4 on Climatronic
Does this mean:
Pin 1 - connector A Pin 20
Pin 2 - connector A Pin 19
Pin 3 - Connector A Pin 4
 :stupid:
Jas
Check your compressor works with the new panel first before doing any wiring changes
Cluster and Key coding
Location Great Yarmouth
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #16 on: November 03, 2014, 05:57:27 pm »
Cheers, will do.
VCDS (Preston, Lancashire)
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #17 on: November 03, 2014, 06:16:53 pm »
Reading through the other links, there seems quite a few problems with the AC etc working afterwards. It seems too complicated for me to attempt on my own, but if we all got together and had an expert on hand to help with the complicated stuff, I might be interested.
A kind of group buy/group fit  :signLOL:
happy to do that, need 5 people to make it viable
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Yorkie92
« Reply #18 on: November 04, 2014, 10:18:42 am »
I just bought one of Bold-Sport last week so I hope its not too hard to fit as i am hopeless with wires  :scared:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #19 on: November 04, 2014, 12:20:27 pm »
If you're hopeless get someone with some knowledge about changing wires. You'll need to modify at least one to make your new control panel keep the settings after you turn off the car.
Offline K9
  • VW LifeStyle
« Reply #20 on: November 04, 2014, 03:08:43 pm »
im in the progess of trying to sort a group buy on these. anyone interested>?
depending on the price.
Offline DamoP
  • -Receive: 115
« Reply #21 on: November 04, 2014, 07:15:10 pm »
price depends on how many people  :signLOL:
Offline K9
  • VW LifeStyle
« Reply #22 on: November 04, 2014, 07:17:19 pm »
i'm in
Offline DamoP
  • -Receive: 115
« Reply #23 on: November 04, 2014, 07:40:45 pm »
1. damop
2. k9
3
4
5
anyone else interested add your name and ill get prices together it we make 5
  • -Receive: 427
« Reply #24 on: November 04, 2014, 07:50:02 pm »
Awesome mod this peeps, such a big improvement of the Mk5 OEM one. I'd highly recommend jumping on a GB, add the AQS sensor at the same time, cheap and def worth it.
Offline DamoP
  • -Receive: 115
« Reply #25 on: November 04, 2014, 07:51:42 pm »
cheers dude, and i know you have already fitted it  :happy2:
Offline Ma22789
« Reply #26 on: December 22, 2014, 06:18:14 am »
If you still doing the group buy im in  :happy2:
  gti ed30 2007 stage 2+ ths loba bcs itg
