Author Topic: Front driveshaft/wheel bearing torque value?  (Read 2846 times)
Offline gazbutS3
« on: January 26, 2014, 10:46:42 am »
As above really fellas, anybody know the correct torque value for the front driveshaft/wheel bearing bolt please?
Offline doylebros
Re: Front driveshaft/wheel bearing torque value?
« Reply #1 on: January 26, 2014, 11:20:49 am »
See if this helps
http://vwts.ru/suspension/g5/g5_40-7.pdf
It may seem confusing but the answer is related to your set up and hub nut.
Offline OSB
  • -Given: 32
« Reply #2 on: January 26, 2014, 11:26:16 am »
According to Haynes - the Hub Bolt is stage 1 tighten to 148 ft lbs, stage 2 angle tighten another 180 deg.
And sorry if I misread the question-  Hub to wheel bearing housing - stage 1 tighten to 52 ibs, stage 2 angle tighten another 90 deg.
Hope that helps
Offline gazbutS3
« Reply #3 on: January 26, 2014, 11:28:58 am »
cheers fellas :happy2:
