Author Topic: Help losing coolant  (Read 1549 times)
Offline pomsteroonie
Help losing coolant
« on: January 26, 2014, 07:53:54 pm »
Hi all
Hope one of you can help me out, I have a 2004 golf GT TDI with 109k on the clock and it has started to lose coolant.
Now from what I can see there is no water in the oil, I cannot notice a sweet smell from the exhaust like it is getting from the water jacket into the fuel and there is no smell in the cockpit or film on the window like it is coming in via the heater matrix.
I've checked everywhere i can see and I can't see any leaks, so I am totally stuck.
The only thing I can notice is she smokes a bit from cold but as soon as the temp hits 90 degrees there is no more smoke.
Any ideas, am I missing something ?
Kind regards
Chris
Offline xjay1337
  • -Receive: 377
Re: Help losing coolant
« Reply #1 on: January 26, 2014, 08:00:10 pm »
Checked around the water pump housing? Bottom of the radiator... if no external leaks it's probably going to be porous cylinder head.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #2 on: January 26, 2014, 08:08:45 pm »
Egr valve / egr cooler is another one to check.
Jas
VCDS (Preston, Lancashire)
« Reply #3 on: January 26, 2014, 08:56:35 pm »
What's a porous cylinder head?
Re:
« Reply #4 on: January 26, 2014, 08:58:54 pm »
Jas
It does smell of exhaust fumes in the car when it's first fired up, I just put it down to a small blow that seals itself up once hot.
Where do I find the egr valve/cooler?
Offline xjay1337
  • -Receive: 377
« Reply #5 on: January 26, 2014, 09:02:20 pm »
 :signLOL: :signLOL: :signLOL:
Common problem micro cracks form in the cylinder heads normally the cylinder walls and allows water into the combustion chamber.
as it does not mix with engine oil there will be no headgasket mayo .
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Re:
« Reply #6 on: January 26, 2014, 09:30:29 pm »
Cooler is mounted on the back of the engine block.
See my guide in the how to thread for pics.
Jas
« Reply #7 on: January 27, 2014, 08:17:27 pm »
Is there any way I can check for this?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8 on: February 01, 2014, 08:23:09 pm »
Unfortunately it is a common problem, especially 2004-2006 on Rev A & B heads.
Best way to determine if coolant is getting into the cylinders is to take it to your local friendly garage and ask them to do a sniffer test.
