Author Topic: Add Bluetooth capability to MP3 stereo  (Read 1173 times)
Offline D Squared
  • -Given: 41
« on: January 27, 2014, 09:23:18 pm »
So I have the OEM stereo which has mp3 written on it, not sure what rcd or rns number it is, has arm rest iPod connection. Is there anyway I can connect Bluetooth capability to it?
2007 5dr GTi
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: Add Bluetooth capability to MP3 stereo
« Reply #1 on: January 28, 2014, 07:02:48 am »
you have an RCD300 MP3 , id go for a handsfree kit that allows pairing as that head units is very low spec and don't think you can get an OEM one
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline D Squared
  • -Given: 41
« Reply #2 on: January 28, 2014, 07:12:17 am »
hmm ok, i keep hearing about these being a low spec unit....would be advantageous to swap the unit then do you think...for perhaps a unit with built in bluetooth?
when i 1st got the car, and saw the unit, i thought it had 6 cd capability due to one of the screens showing 6 cd buttons....i guess that is for a seperate cd changer?
2007 5dr GTi
Offline DamoP
  • -Receive: 115
« Reply #3 on: January 28, 2014, 07:15:02 am »
it depends on how much you want to spend, if you want to keep it original you can go for the RCD310, a very good unit. you will need to change your can bus (use the search bar) loads of threads on how to fit.
Offline D Squared
  • -Given: 41
« Reply #4 on: January 28, 2014, 07:19:48 am »
hmm ok, yes want to keep original, ok i'll have a search about, and of course cost will come into it.....Cheers  :happy2:
2007 5dr GTi
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: January 31, 2014, 01:14:08 pm »
If you just want the capabilty to make/receive calls get something like the Parrot CK3100, i have one up for sale if you're interested. No coding needed, just need to plug it into the quadlock loom at the back of the stereo then run the power wire into the fuse box. Job done :)
http://www.mk5golfgti.co.uk/forum/index.php/topic,78412.0.html
Offline D Squared
  • -Given: 41
« Reply #6 on: February 04, 2014, 12:53:43 pm »
you have a pm...
2007 5dr GTi
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #7 on: February 04, 2014, 04:52:06 pm »
replied
