Author Topic: Need Help - Removing Subframe / VWR dogbone Mount  (Read 1468 times)
Offline GTI-Ross
  • Learning All The Time :)
« on: January 27, 2014, 11:24:42 pm »
Hey guys, potentially looking to buy Andys Subframe with VWR Mount already installed. I just have a few questions and hopefully someone can shed light on it.
So removing the subframe, is it easy enough to do with my mates on my drive (we all have a skill levels of doing jobs around 6 out of 10 - Technical wise) Is this something we can do with a couple of jacks, axle stands and some decent sockets, or is it defo a job for the pro mechanics?
If the mount is already installed, is it just a straight swap or is there a lot more too it? Will i need all new bolts, just stretch bolts and just use the old ones.
Thanks for any help guys.
Re: Need Help - Removing Subframe / VWR dogbone Mount
« Reply #1 on: January 27, 2014, 11:27:17 pm »
Once done you will need to check your alignment...
Offline GTI-Ross
« Reply #2 on: January 28, 2014, 11:47:18 am »
Any other help would be great guys :popcornsoda:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=posug1fvhmg2pdtorqb08ufjv9&/topic,19740.0.html
« Reply #3 on: January 28, 2014, 11:59:50 am »
You can do it on the drive but its a pain, easier to do it up in the air.
Yes... straight swap. IIRC the bolt is a stretch bolt so should be replaced... but Im almost certain there is no real point in replacing it. If you do replace it, it will only be a few quid from VW.
