Author Topic: GPS antenna signal  (Read 1054 times)
Offline Mk5Dom
GPS antenna signal
« on: January 28, 2014, 10:18:41 am »
My mate has an RNS510 retrofitted into her 05 GT. The satellite signal is very intermittent and will work for some time and then all of a sudden loose all satellites and then decide she's driving through a field. More often than not there are no satellites at all.
The antenna is an eBay cheapo with adhesive backing placed behind the clocks.
Should I be looking at getting her a genuine VW antenna or one from someone more reputable like Kufatec?
Dom
Offline Mk5Dom
Re: GPS antenna signal
« Reply #1 on: January 29, 2014, 04:09:14 pm »
No1 experienced this? I've read a few threads but there's not a definitive answer.
Offline SI-R32
  • -Receive: 126
« Reply #2 on: January 29, 2014, 04:14:54 pm »
I know someone that has installed quite a few 510's he always uses the 10 quid gps aerial and locates them under the centre air vent, never had a problem.
perhaps try another one just in case its faulty but if the problem persists i'd be looking at other things
Offline doylebros
« Reply #3 on: January 29, 2014, 05:59:41 pm »
Had a similar experience to the above and eventually had to replace the roof mount with shark-fin c/w extension lead - now perfect every time.
Fitted the puck I removed from MKV into another vehicle MKVI and it worked perfect in that vehicle for the local area.
Took that vehicle (MKVI) to London and it failed sadly - returned with the same vehicle with another Shark-fin same as fitted in my MKV and it was perfect!
So could be the puck isn't good enough for her local area!
Offline Mk5Dom
« Reply #4 on: January 30, 2014, 07:43:04 pm »
Cheers lads.
