Author Topic: Running like S**T  (Read 1301 times)
Offline raptor_tom22
Running like S**T
« on: January 29, 2014, 12:39:07 pm »
Hi all,
This morning my car was running like it was about to run our of fuel. Filled up at shell and when I left intermittently wouldn't rev past around 3500-4000 it was juddering and I must have looked like a descendant of a kangaroo :)
Bit of spec on the car
2005 GTI
DV replaced
PCV replaced with a catch can system
Twintake air intake system
Front mount Twintercooler
Recently replaced the cam follower
around 8000 miles ago the plugs and all 4 coils were replaced
And a regular oil and filter change.
And just to help no warning lights flash up at all during any if it.
Any thoughts or suggestions would be greatly appreciated.
Re: Running like S**T
« Reply #1 on: January 29, 2014, 02:49:12 pm »
Just to be clear, did this start happening after you refuelled?
« Reply #2 on: January 29, 2014, 02:55:58 pm »
Yeah but it has happened very occasionally before and then cleared up and wouldn't do it again for ages.
I used shell v power. I could also hear the exhaust popping a bit when I let off the accelerator which it hasn't done before, It's a totally standard exhaust system.
Wasn't sure whether it could be an injector issue?
Offline 56OctyVRS
  • -Receive: 72
« Reply #3 on: January 29, 2014, 06:18:15 pm »
Have you changed the fuel filter, as if that's blocked it would cause running issues.  Id also get is scanned to see if its raised any fault codes.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: January 29, 2014, 07:42:19 pm »
I've got a spare injector from a 2005 GTI. Yours for £15 delivered  :happy2:
« Reply #5 on: January 29, 2014, 08:45:25 pm »
Thanks for the replies, I've already got a fuel filter but never got round to fitting it so think that will be the first thing to do :)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ttdlaaj7hoguk09qcuv4sa7i03&/topic,19740.0.html
« Reply #6 on: January 29, 2014, 08:49:18 pm »
The catch can... tell us more. Have you emptied it recently?
« Reply #7 on: January 29, 2014, 10:01:01 pm »
Yeah it was emptied couple of weeks ago and is no where near the full mark yet
