Author Topic: yellow wire on kufatec looms for xenons  (Read 2571 times)
Offline D8MOA
« on: January 30, 2014, 12:03:01 am »
does anyone actually connect the yellow wire? if so where the bloody hell do they go  :notworthy:
Offline Matto
  • -Receive: 116
Re: yellow wire on kufatec looms for xenons
« Reply #1 on: January 30, 2014, 02:37:34 am »
I think they feed back to the CECM to allow the shutters to operate when full beam is selected. As to exactly where the feed back to I'm not sure. I'm sure someone can confirm later on though.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: January 30, 2014, 07:21:30 am »
Correct, they run back to the CECM, through the bulk head into the drivers footwell under the steering wheel.
PITA, but well worth the effort as xenons on full beam are immense
If no one updates this in the mean time, i'll post up a couple of links i used when i'm finished work tonight  :happy2:
Offline D8MOA
« Reply #3 on: January 30, 2014, 11:51:30 am »
thanks, im in no rush as not fitting till next week
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #4 on: January 30, 2014, 12:31:28 pm »
I have some time set aside this wekend to install mine, can you post those links please Freddy.
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: January 30, 2014, 05:45:40 pm »
Cecm under the the fuse box, pins A5 and D6, you'll also need it coding for bi-xenons :happy2: cant believe I know the pins off the top of my head :confused:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #6 on: January 30, 2014, 06:54:53 pm »
I couldn't find a definitive guide, i pulled from this guide to get through the scuttle panel and down passed the can gateway
http://www.r32oc.com/topic/29242-canbus-gateway-location-removal/
Then used this guide for the pin location and access to the CECM
http://www.myturbodiesel.com/threads/hid-retrofit-on-mk5-jetta-part-2.2293/
As Morty says A5 for the RH side and D6 for the left
Just remember to wrap the wire first in the black fabric loom tape, those yellow wires stick out like a sore thumb
HTH  :happy2:
Offline D8MOA
« Reply #7 on: January 30, 2014, 10:48:09 pm »
do i need to go to VW and get wiring repair kit with connectors on to be able to fit it into the ecu?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #9 on: January 30, 2014, 11:17:08 pm »
No, the yellow wire should already have the pins on them?  :happy2:
Offline D8MOA
« Reply #10 on: January 30, 2014, 11:34:33 pm »
my looms are used so terminal has been cut off  :sad1:
also finding it difficult to get the connector in the headlight.... GRRRRR :mad:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #11 on: January 30, 2014, 11:47:35 pm »
Do you mean plugging the 10-12 pin adapter into the headlight. Sometimes they can be a little snug but as long you have bought the right one, with some firm but gentle persuasion it should click together :)
« Reply #12 on: January 30, 2014, 11:51:16 pm »
wish i had your lights and front bumper of your golf
Offline mortygttdi
  • -Receive: 146
« Reply #13 on: January 31, 2014, 01:53:58 am »
Sorry mate i wasn't aware at the time that you wanted them, otherwise you know you could have had them :happy2:
Nearly every thing went on the 2 dark side cars, there was only the seats and steering wheel that went into a friend of a friends car which i still haven't been paid for, obviously not a friend anymore :fighting:
Offline QD MBE
  • -Receive: 102
« Reply #14 on: January 31, 2014, 05:35:06 am »
Dug this out again.
