Author Topic: MFSW button retrofit .. Works without coding?!  (Read 2742 times)
Offline jbenekeorr
« on: February 01, 2014, 09:28:13 am »
Hi all,
I have just installed the MFSW buttons onto my standard mk5 DSG wheel and they seem to work with my RCD510 - they control the volume and mute. However the buttons on the right seem to control the trip computer rather than skip tracks.
If I get them coded with VCDS will they control the skip track function or not?
I have the midline FIS (smaller one) if that makes any difference.
I have someone who can do it for me today but if it's not going to make a difference then it saves me a trip.
Thanks!
Offline edd666999
  • -Receive: 89
Re: MFSW button retrofit .. Works without coding?!
« Reply #1 on: February 01, 2014, 10:04:33 am »
With midline, the way they are currently working is normal.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: February 01, 2014, 10:05:50 am »
If you had a Highline
you would go into the AUDIO menu and then the buttons on the right would change track
Cluster and Key coding
Location Great Yarmouth
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #3 on: February 02, 2014, 09:32:21 pm »
As above - I originally had MSFW buttons added when I had a midline - the volume buttons worked, and the right hand buttons changed the MFD screens between MPG, DTE, hours driving, etc. When I had a hi-line fitted, I then had the full functionality - the right hand buttons now allow me to change track from the wheel.
Eddie did the cluster swap on mine - great chap, and can thoroughly recommend him if you need any coding / retrofits!
Edition 30 - no. 1387
