Author Topic: New Matt Black Emblems and Debadged  (Read 5326 times)
Offline irish_ram
  • -Given: 200
« on: February 01, 2014, 04:25:19 pm »
Well received my rear and front Matt Black Emblems this week and finally got round to fitting them today. Also decided to do a De-badge while as was looking at doing it and once I put the new Emblems on the Silver badges did not look right anymore so got rid.
For anyone else looking at doing it here is my 2p's worth if it helps:
Front Emblem - Eurowagons on Ebay for £19.99 and delivered with 2 days
DIY - Simple put a bit of pressure on the badge and twist anti-clockwise(be careful as can break the clips if force too much). Then wiggle and pull until all clips out. I found that if you can initially loosen one clip the emblem comes out enough for you to be able to use your finger or a tool to gently pries the other clips off. Then it is as simple as putting the new Enblem at the correct angle and twist to the right so it clicks in.
Before
After
Rear Emblem - Got from brookesb32(Top notch work  :happy2: ) for £54 and next day delivery
DIY
1. Unscrew the 2 screws on the handles on the inside boot hatch
2. Then using your hands(I recommend gloves or a towel to cover them) slowly pull away the hatch cover until the clips click out. They are very stubborn and took me a good 10mins to pries them all off.
3. Now unscrew all the torq screws on the back of the Boots handle. There is one tricky on which I managed with a torq screw driver to loosen and then did the rest with my hands as it can be tricky. You can undo the wiper mechanism to get at this screw but seemed a bit overkill to get to this last screw. Then twist and the Handle will drop out. Unclip the cable on the handle lastly.
4. Clip the cable into the new Handle and insert into the slot and then put 3 screws back in.
5. I do not know how these handles work but I tested mine worked before putting the Hatch inside back on.
6. Lastly put the hatch inside back on which was trickier than removing but took me about 10 mins.
Before
After
De-Badge - Cost nothing apart form the few quid for Dental Floss and cleaning products if not already got them in household
DIY -
1. Using a hairdryer heat the Letter/Numbers for about 20 seconds
2. Using some Dental Floss slowly work it in behind each letter/number and it should slowly come off. Repeat on other letters/numbers
3. Heat up for about 20 seconds any excess glue stuff left on the car an then peel off with fingers.
4. Then using your cleaning product(I used normal kitchen surface cleaner and dettol wipes) clean the area thoroughly to remove any leftover glue. You may have to do this a few times until glue is gone and ghosting also.
Before
After
Thanks again to brookesb32 for the rear emblem.
Would like peoples opinions even if it is not to your liking  :confused:
Offline candy turbo
Re: New Matt Black Emblems and Debadged
« Reply #1 on: February 01, 2014, 07:24:32 pm »
Love the front not so keen on the rear thats why ive left mine alone !
Offline Stanipkiss
« Reply #2 on: February 01, 2014, 07:30:40 pm »
Liking the front but the rear maybe needs some red behind the badge IMO
Offline irish_ram
  • -Given: 200
« Reply #3 on: February 01, 2014, 07:44:32 pm »
Cheers guys,
I definitely love the front especially as it was so easy to replace.
I also am glad I de-badged but the more I look at the rear I can see what you mean.
The front has enough black elsewhere and the 3D look to blend in nicely but the back one does look like it may need something like red in between the black VW.
Anyone any good with photo shop or something that would not mind changing the black to red in between the VW to see what it would look like?
Offline J12spk
  • VW PERVERT
« Reply #4 on: February 01, 2014, 09:00:52 pm »
Here's mine colour coded mate, you defo need to do it!
Another great brookesb32 job!
 :wink:
Das Auto
Offline G40will
« Reply #5 on: February 01, 2014, 09:08:37 pm »
Looks good mate, got any pics of the front from further away? I like the gt grills but you don't often see them in black on a red car.
Offline JaseGti
    • Remoteclothing
« Reply #6 on: February 01, 2014, 09:10:51 pm »
Get some red inserts for the badge on the rear and would look much cooler
CW is the way forwards
Remoteclothing.com
Offline irish_ram
  • -Given: 200
« Reply #7 on: February 01, 2014, 09:56:29 pm »
 :wink:
Does look good on yours.
Totally off topic what wheels you gt on your car as I am looking for some and they look nice
Offline irish_ram
  • -Given: 200
« Reply #8 on: February 01, 2014, 09:58:58 pm »
I have not at the moment. I will take some for you tomorrow and post up.
I was not aware my front gt sport grill was any different to the standard one or is it you have not seen them on a red car. If so what have you seen on a red for the grill?
Offline Melvin084
« Reply #9 on: February 01, 2014, 10:00:55 pm »
There R32 wheels bro :wink:
Offline GTI-Ross
  • Learning All The Time :)
« Reply #10 on: February 01, 2014, 10:17:59 pm »
£54 for a rear badge, I swear people are losing their minds. I could understand it it made it look a lot better, but that rear badge makes it look awful  :sick: :sick:
Save money like that and get something decent like R32 cherry lights.
Offline J12spk
  • VW PERVERT
« Reply #11 on: February 01, 2014, 10:18:57 pm »
What he says!!!!!
Das Auto
Offline irish_ram
  • -Given: 200
« Reply #12 on: February 01, 2014, 10:23:31 pm »
Each to their own taste mate. £54 is a good price for the whole boot handle as I do not think you would get it much cheaper anywhere else.
And for my personal preference I like it and feel it improves the car which is all that matter  :happy2:
And even if I was not a fan I do not think anyone on this forum can say they have never bought anything that the minute they stuck it on the car they went I am  :stupid:  :happy2:
Thanks for the feedback though  :grin:
Offline J12spk
  • VW PERVERT
« Reply #13 on: February 01, 2014, 10:26:18 pm »
Don't worry Irish, once u got the red inserts in it will look just as good as GTI-Ross mk6 golf!  :fighting:
Das Auto
Offline GTI-Ross
« Reply #14 on: February 01, 2014, 10:29:45 pm »
C'mon man, you know its true....Spend money to enhance, not hinder the look
