Author Topic: Stage 1 logs  (Read 3186 times)
Offline Marshall
Stage 1 logs
« on: February 02, 2014, 02:22:02 pm »
As the title I've been logging my S3 with Revo stage 1 today.
I've ordered a new revision G diverter valve as it looks like I'm losing some boost.
Out of the 2 logs which settings would you advise
1st one
B7 T6 F9
Next one is
B7 T5 F9
MISANO RED RS3
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
Re: Stage 1 logs
« Reply #1 on: February 02, 2014, 02:33:45 pm »
Both are fine, you can run a tiny bit more timing if you wish.
You don't want to be seeing more than 3-6 on the cyclinder.
Tornado red ed30 #0728
Offline Marshall
Re: Stage 1 logs
« Reply #2 on: February 02, 2014, 02:38:20 pm »
What do you think about the boost?
I'm assuming my dv is leaking slightly as I've replaced my pcv.
Not on that log but fuel pressure difference is below 2 so that should be ok?
MISANO RED RS3
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=3q5ncmmr6n3vgtki2ogvkobuuu&/topic,19740.0.html
Re: Stage 1 logs
« Reply #3 on: February 02, 2014, 02:39:30 pm »
yeah 1.3bar is fine  :happy2:
Offline Marshall
Re: Stage 1 logs
« Reply #4 on: February 02, 2014, 02:45:24 pm »
Thank you
Would you run boost 8 on a stage 1?
MISANO RED RS3
Re: Stage 1 logs
« Reply #5 on: February 02, 2014, 02:46:35 pm »
If its the latest file you can use 9. 9 is more aggressive, where as 6 is more progressive.
Offline Marshall
Re: Stage 1 logs
« Reply #6 on: February 02, 2014, 02:59:10 pm »
Yeah on the latest software.
MISANO RED RS3
Offline cuprajake
Re: Stage 1 logs
« Reply #7 on: February 02, 2014, 04:05:33 pm »
Boost will never match exactly as the cars overshoots it will cut boost a little then add more to male it up yours looks fine.
Offline Marshall
Re: Stage 1 logs
« Reply #8 on: February 02, 2014, 04:46:35 pm »
Thanks for your help.
I've set my sps to
1= 669
2=769
3=869
Will try each over the next few days :happy2:
MISANO RED RS3
Offline Marshall
Re: Stage 1 logs
« Reply #9 on: February 08, 2014, 09:34:19 pm »
I've just ordered a Loba hpfp which should be here wedensday.
What do I need to log regarding setting my fuel setting on my sps?
I see lots if people are running fuel 6 but I want to be sure.
MISANO RED RS3
Re: Stage 1 logs
« Reply #10 on: February 08, 2014, 09:36:28 pm »
You need to log the fuel rail... actual vs specified. Block 230 i think
Offline Marshall
Re: Stage 1 logs
« Reply #11 on: February 08, 2014, 09:38:39 pm »
So do I just need to make sure target and actual match?
MISANO RED RS3
Re: Stage 1 logs
« Reply #12 on: February 08, 2014, 09:46:20 pm »
Take a read on here...
http://www.revotechnik.com/resources/uploads/files/SPS_AdvancedUserGuide_V0707.pdf
Im pretty sure that the REVO stage 1 file doesnt take into account the upgraded HPFP so wont really make much difference
Offline Marshall
Re: Stage 1 logs
« Reply #13 on: February 08, 2014, 09:53:58 pm »
Thanks for the link
It shows I need to log the AFR
MISANO RED RS3
Offline JMP
Re: Stage 1 logs
« Reply #14 on: March 01, 2014, 07:55:02 am »
Your second run from 2240rpm to 6200rpm is faster, 6.34s vs 6.19s, so you have more power. This is assuming you did the runs in same place, direction etc..
