Author Topic: Just bought some OEM xenons..  (Read 2548 times)
Offline vaheedakhtar
« on: February 07, 2014, 09:54:48 pm »
Now can someone clarify what, exactly, I will need for these to work properly?
Will I need any canbus stuff?
What about the shutters, can someone post a link of how these will be operated?
Thanks in advance for any help.
Offline xjay1337
  • -Receive: 377
Re: Just bought some OEM xenons..
« Reply #1 on: February 07, 2014, 10:24:36 pm »
There are guides of how to wire up the Bi-xenon shutter. You need to wire it to a pin in the CECM.
http://www.myturbodiesel.com/wiki/jetta-golf-headlight-removal-and-oem-gti-hid-xenon-housing-retrofit/
Plenty of info on this site as well.
You need VCDS to enable the xenons too.
« Reply #2 on: February 07, 2014, 11:52:19 pm »
Cheers mate.
It looks quite complicated. I was hoping they'd be a bit more 'plunge and play' !
Offline xjay1337
  • -Receive: 377
« Reply #3 on: February 07, 2014, 11:56:44 pm »
It's not really hard at all  :scared:
Use plug adaptors and VCDS and they work fine..
Bi-xenons is run one wire, not hard :)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #4 on: February 08, 2014, 12:33:47 am »
I'll be fitting mine Sunday (if the damn weather improves) the hardest part is removing the under tray!
Offline George10
« Reply #5 on: February 08, 2014, 10:14:45 am »
Yeah I'll second that. The lights are easy to fit/ wire up, but if you don't have a highline cecm unit you won't your bi xenon won't work.
Offline mortygttdi
  • -Receive: 146
« Reply #6 on: February 08, 2014, 08:26:29 pm »
You can use any of the cecm's you just need to know which byte and bit to tick? The tick box is there it's just there's no description at the side so your shooting blind! But if you know which it is it will work.
Offline George10
« Reply #7 on: February 08, 2014, 11:02:45 pm »
I stand corrected
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
« Reply #8 on: February 08, 2014, 11:28:40 pm »
whats involved with wiring these up oem? I.E Using original looms and installing the load sensors and gubbins?
 :scared:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #9 on: February 08, 2014, 11:43:56 pm »
I stand corrected
Said the boy with an orthopaedic shoe
Don't worry i know my way out..............................
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #10 on: February 08, 2014, 11:47:17 pm »
 :scared:
Not sure what you mean by load sensors. If you want to just install the headlights you'll need an adapter lead or you can go for a full installation including washer jets and levelling sensors. The latter will not be cheap!!
Just for clarity. You DO NOT need to install washer jets and levelling sensors for the car to pas an MOT
Offline Gman30
« Reply #11 on: February 09, 2014, 01:22:57 pm »
[/quote]
I meant levelling/load sensors mate... Do you know whats involved with this? Anyone on here done it?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #12 on: February 09, 2014, 01:28:27 pm »
Installing leveling sensors is on my list of mods, I just need one more sensor which is proving to be a PITA to find.
« Reply #13 on: February 09, 2014, 02:34:41 pm »
Hi mate, do you have a link to the plug adapters that you're talking about? I received a message from a forum member, just to let me know that they're selling some kufatec xenon conversion things. Is this what you're talking about?
« Reply #14 on: February 09, 2014, 02:37:32 pm »
My car has the full  highline cecm. So I should be ok to go? I'll have to borrow a VCDS from somewhere though.
What parameters need changing on it?
