Author Topic: Name of this mod and how to get it  (Read 3928 times)
Offline carljackson
« on: February 09, 2014, 03:18:15 pm »
I have seen many of you guys with this mod on you're car and I would like to know how i can get this onto my standard headlights. Is there a part I need to buy and if so can you provide me with a link please thanks
I am reffering to the white side lights, I went to someone which has a VAGCOM but they couldn't do it for me seen as my headlights don't have anything inside that section in order for it to be programmed its basically empty. I would like to know if anyone has any good links/places on where I can buy this daytime running light mod please drool
« Last Edit: February 09, 2014, 04:19:26 pm by carljackson »
Offline flufgti
Re: Name of this mod and how to get it
« Reply #1 on: February 09, 2014, 03:20:26 pm »
Its done with vagcom cant rember what youhave to go into but.
Offline George10
« Reply #2 on: February 09, 2014, 03:42:46 pm »
Are you on about the white sidelight?  Or the  orange?
As 'flufgti' said it's done on vagcom which allows the American look.. A few people also get orange side light bulbs to make it more visible
Depending where you are there's a fair few people on here that can then them on for you
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #3 on: February 09, 2014, 03:43:49 pm »
It's the US spec look called DRL daytime running light mod done with VAGCOM.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline Marc-5-GTI
« Reply #4 on: February 09, 2014, 03:45:30 pm »
never knew about this, I might get this done next time the car is in the garage  :happy2:
Offline alexmccabe
    • Alex McCabe
« Reply #5 on: February 09, 2014, 03:48:20 pm »
I have mine set to 50%. Be careful when you take it for MOT as they might fail you for it. I had to explain to my MOT tester what it was and why it was doing it as they were worried about it affecting the visibility of the indicators.
MK5 Golf GTi 197BHP Tornado Red
Offline carljackson
« Reply #6 on: February 09, 2014, 03:54:47 pm »
I am reffering to the white side lights, I went to someone which has a VAGCOM but they couldn't do it for me seen as my headlights don't have anything inside that section in order for it to be programmed its basically empty. I would like to know if anyone has any good links/places on where I can buy this daytime running light mod please :drool:
Offline Marc-5-GTI
« Reply #7 on: February 09, 2014, 04:01:42 pm »
Is it only a Xenon thing?
I hope not!  :fighting:
Offline G40will
« Reply #8 on: February 09, 2014, 04:10:25 pm »
The orange is the indicator bulb set with vagcom and the white is just the side lights.
It looks better on xenons as both lights are at the bottom of the headlight so makes it appear to be a whole strip of pith at the bottom.
It is programable on halogen type headlights, it just doesn't look as good as xenons.
« Last Edit: February 09, 2014, 04:12:15 pm by G40will »
Offline pitsirikas
  • -Given: 19
« Reply #9 on: February 09, 2014, 04:14:28 pm »
If I understood correct this is what you want:
http://www.mk5golfgti.co.uk/forum/index.php/topic,73491.0.html
                     Don't drive faster than your angel can fly..!
                Respect a man's car and the man will respect you
Offline S4nup
« Reply #10 on: February 09, 2014, 11:06:22 pm »
Only xenons have the sidelight next to the indicator. Halogens have them in the high beam. Most you can do is the short indicator section on halogens.
Offline carljackson
« Reply #11 on: February 09, 2014, 11:43:17 pm »
S4NUP Yes this is what I wanted to know, I was confused on why only the indicator section could light up after being programmed and wanted to know if there was a led strip I could buy online so the whole indicator section could light up. So I'm guessing the only alternative of getting the full section to light up is by buying xenons right?
Oh ok thanks for you're help guys. Sorry but I didn't make my question very clear, I had to edit it in the end :notworthy:
