Author Topic: noise whilst braking at low speed  (Read 1370 times)
Offline south
« on: February 11, 2014, 02:39:26 pm »
Long time lurker first time poster!
Picked up a 55 plate at the weekend and after 400 miles the breaks have started to sound extremely worn - at low speeds it's most noticeable (no squeaking but a rough grinding sort of sound). The breaks also don't seem as sharp as I'd expect. I've checked both pads and discs and they're fine (plenty of pad left, no scoring or rust on discs. Also free of any potential debris.
Does anyone have a suggestion of what it could be or what else to check?
Offline Carpy25
Re: noise whilst braking at low speed
« Reply #1 on: February 11, 2014, 02:50:13 pm »
are the discs grooved ? they can be noisy at low speed with light pedal pressure my fronts squeak like hell and more pedal pressure it stops
Rob
Offline south
« Reply #2 on: February 11, 2014, 02:55:57 pm »
Rob
Nope, flat and plain... really grainy noise rather than squeaking!
Offline skard
  • -Receive: 245
« Reply #3 on: February 11, 2014, 02:57:44 pm »
Was the car standing a while? Worth taking out the pads and see if they could benefit from a rub with some emery paper.
Check there are no stones caught between the splash shield and the disc too.
Offline Human Joist
« Reply #4 on: February 11, 2014, 02:58:08 pm »
Chuck a picture of the set up mate. Might get more help
Offline south
« Reply #5 on: February 11, 2014, 03:51:14 pm »
Unsure, potentially but good suggestion, thanks Skard. It's just the bog standard OEM setup, will snap some pics on the weekend if I can't otherwise resolve it.
Offline south
« Reply #6 on: February 11, 2014, 05:49:23 pm »
Popped it into the local... disks were grooved, had them taken back and smoothed off and all is a.ok  :happy2:
