Author Topic: OEM xenon headlights vs aftermarkets?  (Read 1678 times)
Offline K9
  • VW LifeStyle
« on: February 12, 2014, 08:42:30 pm »
hey, been searching a time for a answer to this, whats the difference between OEM xenon headlights and aftermarkets?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: OEM xenon headlights vs aftermarkets?
« Reply #1 on: February 12, 2014, 10:12:21 pm »
A lot of the aftermarket are xenon look so use normal bulbs not xenon bulbs. Plus to do xenons correctly you would want (may technically don't have to have I believe) the levellers and washer jets
Offline xjay1337
  • -Receive: 377
« Reply #2 on: February 12, 2014, 10:23:37 pm »
project units in OEM ones are generally higher quality
Better beam pattern.
Aftermarket ones are not designed to use HID bulbs... you have to use HID kits..beam pattern is often OK though.
But yeah, not quite the real deal.
Offline K9
  • VW LifeStyle
« Reply #3 on: February 13, 2014, 08:49:20 am »
how can you tell if a golf mk5 gti have oem xenon headlights or aftermarkets?
Offline SkyJawa
« Reply #4 on: February 13, 2014, 09:01:21 am »
Phone vw with your reg or vin number and ask what options are fitted!
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #5 on: February 13, 2014, 09:37:04 am »
Also check out the light switch in the car, genuine XENONS wont have the beam adjustment wheel as they self level
Offline xjay1337
  • -Receive: 377
« Reply #6 on: February 13, 2014, 09:46:31 am »
Yup exactly the oem xenon will auto level on start up.  You can also check for the ballasts and bulbs on the back of the headlight along with any part numbers.
.simple enough really
Offline Sandbagsniper
« Reply #7 on: February 13, 2014, 01:20:12 pm »
I bought my car with aftermarket xenons. They look great from the outside. Problem is that I don't have a clue where to look for a part when the bulb/ballast stops working.
I doubt VW dealer will touch it either.
Offline K9
  • VW LifeStyle
« Reply #8 on: February 13, 2014, 01:31:24 pm »
Thanks! But the car didn't come with oem xenons, i mean that they changed the headlight to a oem headlight. How can i see if its a aftermarket unit or oem light?
Skickas från min iPhone via Tapatalk
Offline xjay1337
  • -Receive: 377
« Reply #9 on: February 13, 2014, 01:38:08 pm »
Ebay? Lol. Its just a hid kit with h7 bulbs.
