Author Topic: brake pedal goes hard randomly.  (Read 6111 times)
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« on: February 13, 2014, 10:12:35 am »
The problem is that randomly the pedal goes rock solid, when im driving along is only done it 2/3 times now
If I pump the brakes when the cars off then start the car it goes down a little
And if I'm driving along and press the brakes more than 4 times,( on off on off)  it goes hard and doesn't really slow the car down
What's up with it?
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline Gra
Re: brake pedal goes hard randomly.
« Reply #1 on: February 13, 2014, 10:18:04 am »
Sounds like a vac pipe split?
Offline reaper7881
« Reply #2 on: February 13, 2014, 10:21:12 am »
Where is it.on a  Mk5 golf 1.9tdi
Offline Karl_mac_
« Reply #3 on: February 13, 2014, 11:22:13 am »
Could be worth bleeding the system to rule out air in the fluid.
VW Golf GTi DSG2.0 TFSI : DSG : BBS LM : Blueflame exhaust : Pipercross Venom Induction : Eibach Springs
VW Lupo1.4l : Automatic : White : Stickers.
Offline Gra
« Reply #4 on: February 13, 2014, 07:42:34 pm »
Not sure mate but first thing if check is fluid levels check for air in system as above and all vac pipes etc
Offline Gra
« Reply #5 on: February 13, 2014, 07:42:48 pm »
Does it stay down?
Offline reaper7881
« Reply #6 on: February 13, 2014, 08:13:03 pm »
No it comes back up like normal
Offline Simmo
« Reply #7 on: February 14, 2014, 07:19:10 am »
+1
Has the brake fluid gone down significantly?
Offline paulw123
  • -Receive: 47
« Reply #8 on: February 14, 2014, 02:32:17 pm »
vac pipe split, need to check them all carefully. Bloke at work had same thing last week.
cheapest place to start looking anyway.
