Author Topic: Coked intake valves at 39k miles  (Read 6683 times)
Offline Chris92
  • -Given: 33
Re: Coked intake valves at 39k miles
« Reply #15 on: February 16, 2014, 07:24:50 pm »
You will get some oil past the turbo seals so you can never prevent carbon build up.
IIRC VRSAlex cleaned his valves, then fitted a catch can and checked the valves after 8k and they were coked up again  :sad1:
May take a little longer without the PCV system blowing oil in though.
Yep.
So would you still say it's worth fitting a catch can to slow down the build up? Or I'm I better off not to bother
Offline vRSAlex
  • -Receive: 253
« Reply #16 on: February 16, 2014, 07:50:12 pm »
There isn't really any catch cans that work well enough.
I use a combination of a huge forge r32 baffled can, 42dd plate and larger hose.  Had to remove the carbon canister to get it all to fit.
Ideally you want all the vapours to release to atmosphere, but the vapours stink and will give you a headache.
Follow AKS tuning on Facebook
Offline phelan77
« Reply #17 on: February 17, 2014, 06:34:03 am »
So, basically there is no permanent solution to this problem?
Saintsteve
« Reply #18 on: February 17, 2014, 08:08:57 am »
No
« Reply #19 on: February 17, 2014, 03:14:50 pm »
No
Wrong, just don't run the engine...   :evilgrin:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #20 on: February 17, 2014, 03:41:59 pm »
Take it apart and clean it every month  :signLOL:
Silver is the way !
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #21 on: February 17, 2014, 03:49:54 pm »
A few guys on here have messed around with catch cans and found the car runs better with the OEM PCV system  :surprised:
Coked up valves is inevitable so why waste £300+ on a catch can  :stupid:
Offline Stig_gti
« Reply #22 on: February 17, 2014, 04:18:10 pm »
How much is it to have them cleaned
Offline flashp
  • -Receive: 65
« Reply #23 on: February 17, 2014, 09:25:31 pm »
Probably a few hours labour and a small cost for materials.
Gone but not forgotten :-)
