Author Topic: Are these VCDS codes anything to worry about?  (Read 1515 times)
Offline J400uk
  • -Receive: 27
« on: February 15, 2014, 08:05:32 pm »
So I did a quick scan on my newly purchased GTI and a few old fault codes are coming up. Car drives perfectly with no warning lights illuminated and it had quite a lot of work done last month, including a new PCV. Based on that would it be safe to assume these codes don't mean anything serious? Hoping it just means the module hasn't been cleared properly rather than actual problems that need attention! See below...
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0020
   Revision: --H14---    Serial number: VWZ7Z0E2961366
   Coding: 040300031C070060
   Shop #: WSC 00094 210 71533
   VCID: 2D51CF49B4F69704C2D3ED
5 Faults Found:
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
               P1297 -- 001 --  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 152347 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:07:39
             Freeze Frame:
                    RPM: 1313 /min
                    Load: 39.2 %
                    Speed: 0.0 km/h
                    Temperature: 18.0°C
                    Temperature: 8.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.605 V
004244 - Bank 2; Fuel Measuring System 2
               P1094 -- 008 -- Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 152347 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:28:05
             Freeze Frame:
                    RPM: 1500 /min
                    Load: 12.5 %
                    Speed: 20.0 km/h
                    Temperature: 36.0°C
                    Temperature: 12.0°C
                    Voltage: 14.351 V
008597 - Oxygen (Lambda) Sensor B1 S1
               P2195 -- 008 -- Signal too Low (Lean) - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 152351 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:06:48
             Freeze Frame:
                    RPM: 762 /min
                    Load: 27.4 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.097 V
012559 - Unknown Error Code
               P310F -- 002 --  - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 153822 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:25:24
             Freeze Frame:
                    RPM: 619 /min
                    Load: 33.3 %
                    Speed: 0.0 km/h
                    Temperature: 69.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 13.589 V
000679 - Unknown Error Code
               P02A7 -- 002 --
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 154306 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:34:18
             Freeze Frame:
                    RPM: 4519 /min
                    Load: 90.2 %
                    Speed: 88.0 km/h
                    Temperature: 87.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0000
Re: Are these VCDS codes anything to worry about?
« Reply #1 on: February 15, 2014, 08:22:00 pm »
If the car runs ok with no warning dashboard lights illuminated, I would clear the codes and rescan after 10-20 miles.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #2 on: February 15, 2014, 10:08:30 pm »
Perhaps the divertor valve? Early ones Prone to splitting
« Reply #3 on: February 15, 2014, 10:22:20 pm »
I'm thinking the repair was probably carried out but the original faults weren't cleared.
Offline J400uk
  • -Receive: 27
« Reply #4 on: February 22, 2014, 10:43:43 am »
Good news everyone, scanned it again today after a week and all the codes have gone! Seems it was fine, probably as above just never got cleared when the PCV etc was done  :drinking:
« Reply #5 on: February 22, 2014, 11:12:36 am »
