Author Topic: Key fob programmed with vagcom, light on key flashes but no unlock/lock ?  (Read 1218 times)
Offline BcPitta
been like this since i bought the car, at first there was no flashing light on the key, bought a new battery and now it flashes fine with every button, so got vagcom on, programmed both my keys in ( all start the car fine by the way) both give the acceptance hazzard flash when you hold the fob button while there being programmed in the ignition, but as soon as you take them out it doesnt do any thing, no lock no unlock no boot pop ? , ive just ordered a central convenience module from ebay (£10 so thought may aswell) hoping that will work, if not is there anything else that could be causing it ? where is the receiver for the signal ? all fuses are fine. cheers
« Last Edit: February 16, 2014, 04:06:59 pm by BcPitta »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Key fob programmed with vagcom, light on key flashes but no unlock/lock ?
« Reply #1 on: February 16, 2014, 04:11:41 pm »
any faults on the car?
Cluster and Key coding
Location Great Yarmouth
Offline BcPitta
« Reply #2 on: February 16, 2014, 04:25:10 pm »
not to my knowledge mate, just my passenger wing mirror bulb is out
Offline BcPitta
« Reply #3 on: February 20, 2014, 02:05:42 pm »
Installed the new Comfort control module today, reprogrammed the fob via vag com , got the hazard flash to say its paired, now i click the buttons, i can hear a click in the box but still no lock/unlocl/boot atall and its driving me mad, i have another fob and that wont interact atall, please someone help!
Offline doylebros
« Reply #4 on: February 20, 2014, 03:51:10 pm »
Check the frequency of the keys and module they have to match!
This may explain it
http://www.golfmkv.com/forums/showthread.php?t=38548
« Last Edit: February 20, 2014, 04:05:10 pm by doylebros »
Offline BcPitta
« Reply #5 on: February 21, 2014, 05:44:49 pm »
Right ive been at it again, i put just the metal key half in the ignition and kept the originial fob in my hand just over the handbrake, recoded the fog clicked the button while stil holding it over the handbrake so nowhere near the ignition barrel and it still gave the conformation flash, so the car is rieceving the signal from the fob ( the other fob i bought doesnt link up so that makes sense with doylebros post as this had a differnet number from the original fob thanks for that dude) but still the key doesnt lock or unlock the car, ive been through must be all the menus on vagcom and no where can i see an option to disable the fob, i really dont wanna have to take this to a dealer but my options are looking slim
Offline doylebros
« Reply #6 on: February 21, 2014, 07:21:07 pm »
If your following this procedure and it completes the process I would think the fob is still the faulty item!
http://m.youtube.com/watch?v=jdakPlMnDr4
Offline BcPitta
« Reply #7 on: February 21, 2014, 08:19:50 pm »
but ive done it 3 time and each time used a different button on the fob to activate and each time the car accepts the fob and gives the hazard flash, so i dont get how it can be the fob ? but ill see if i can get another spare from somewhere and have another go, thanks for your help bud
Offline twalters
« Reply #8 on: February 21, 2014, 08:27:00 pm »
Where abouts are you? I travel a lot, carry spare remotes, could help narrow the problem down. Sounds like ccm and fob are good, maybe a fuse / relay/ plug elsewhere failing.
Offline BcPitta
« Reply #9 on: February 22, 2014, 11:08:39 am »
Im in sheffield buddy, would be a big help if you could mate, i dont mind sorting some beer tockens for you :drinking:
