Author Topic: ***Deep-Shine Detail*** Pitch Blue Metallic Matt Vinyl Wrap Audi A3 Air-Ride!!!  (Read 13478 times)
Well here is another Vinyl wrapped Audi A3 we have recently completed at Deep-Shine Detail.  :smiley:
Here is the full report.
(...if anyone has any questions feel free to contact us)  :wink:
Audi A3 Receives a full colour change wrap @ Deep-shine Detail to Pitch Blue Metallic Matt.
The A3 under went the usual full safe wash and contamination process then was moved inside and fully clayed to remove bonded more stubborn contaminates & Dried using a hot air blower before being fully stripped down in preparation for wrapping.
How the A3 looked before
The car was then prepared properly fully removing and striping all trim, bumpers, mirrors, spoiler and lights etc to ensure the best application of the wrap as possible.
The colour :thumb: Pitch Blue Metallic Matt which is an awesome colour and finish.
Let the transformation begin
Door Handle Recesses post heated to 90 degrees to change the memory of the vinyl to ensure it holds its new shape.
Door handles and bump strips etc that were removed are fully cleaned, old adhesive strips removed, wrapped, new 3m adhesive tape applied and re fitted.
Cut tape is used at every opportunity possible to avoid any cutting onto the cars   paint. As the A3 Roof runs flush the cut tape is essential to create a safe and accurate join.
Bumpers dry fitted to be wrapped
Due to a bad repair on the original tailgate a new one was sourced so this was fully prepared, wrapped and refitted.
Carlo ensuring the relevant areas are post heated to the correct temperature and carefully monitoring with a infra red thermometer
Mirror caps removed, wrapped & refitted.
The Car was then fully re assemble giving us the finished result. :thumb:
Many Thanks for looking Adi/Carlo @ Deep-Shine Detail
  • -Receive: 427
Just gets better each time!  :notworthy:
Offline arris
Looks stunning!
Your attention to detail is awesome, is this a local car?
excellent work again--just amazing work and the detail and stripping the parts of to do the job is good to see :happy2:
Offline J12spk
  • VW PERVERT
That wrapping is simply stunning! How much should something like that cost?
Das Auto
Offline jaffa
  • -Receive: 44
great work as usual  :happy2:
just out of curiosity how does the cut tape work?
Offline Rob.
Beautifully clean work  :congrats:
Offline GTI.Dav
Great work guys! Nice colour choice  :happy2:
Looks stunning!
Hi mate, thanks for the compliments and yes it's a young Lincoln lad.  :happy2:
It will look totally different with his "Show Wheels" on. (10.5" rears)  :surprised:
Thanks Martin.  :wink:
Cheers Andy, when you coming down for yours doing then?  :laugh:
Pm'd you mate  :happy2:
The cut tape is awesome. Basically it's a 3mm wide tape with a filament running down one edge.
You run the tape where you want to cut a line or a curve etc and press it on firmly, leaving excess cut tape overhanging at each end. Then you lay your vinyl over the cut tape and again press firmly using cards/gloves etc.
Then using a knife carefully separate the filament on one end of the cut tape.
With a very firm hold of the filament pull confidently through the vinyl in a clean movement all the way to the other end.
Then remove the vinyl off cut and the remains of the cut tape.
Job done.  :smiley:
mine is in the paint shop at the mo getting the wings done but would mine doing at some point
^^^^No worries dude  :wink:
Offline Rob.
How did this one get finished in the door shuts etc?
